Battery dead again - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-23-2013, 09:39 AM Thread Starter
Date registered: Jul 2013
Vehicle: E350 Wagon 2011
Battery dead again
My E350 wagon is 2 1/2 years old with 20,000 miles. The car wouldn't start about two weeks ago and I had to put it on a charger. The car had been sitting in the garage for more than a week. Yesterday the battery was dead again; the car had been sitting for 4 days. I have never had a car that needed a battery before the 5th year (even cars we had in Arizona that sat much of the time). Before I call the dealer, a couple of questions:
1. With another German car brand they recommend locking the car when left in the garage as that 'puts the computers to sleep' and cuts current draw.
2. Is my kind of problem common in e350s that sit a week at a time.
3. Does anyone know what the current draw should be when the car is parked- unlocked and locked. I will ask the dealer to check but would like to know what it should be.
4. In a search I read that these cars have a backup battery. If this is correct where is it located and what limited functions does it support?
5. Is the primary battery conventional lead acid?
6. I use battery maintainers on my other cars that sit for periods of time. Maybe I will have to do that on the E350 even though it sits for relatively short periods. If so what maintainers are others using? Do you have to buy the M-B brand or will Battery Tender or Interstate work as well?
Will appreciate your help and advise, Jim B
jamesmb is offline
post #2 of 8 (permalink) Old 07-23-2013, 11:23 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
What kind of driving do you do in terms of distance per trip?
flyboyike is offline
post #3 of 8 (permalink) Old 07-23-2013, 12:00 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Jim,
With your car being as new as it is and I assume it must be under warranty, why not let the dealership look at it. If it is something like a phantom draw, it is a pain to track down on your own.
Mike
Michael Pillay is offline
post #4 of 8 (permalink) Old 07-23-2013, 12:23 PM Thread Starter
Thanks to both for replies. Half of trips are 10-15 miles, other half are 30-50 miles. That may be part of problem but my wife's car is driven less often and on shorter trips- a 2006 Lexus LS 430. It has its original battery which has never needed charging. Also have a few 'fun' cars which see limited use but seem more resilient at holding charge. As suggested I've got the car scheduled for service on Thursday. Service rep said that wasn't right & they would check out charging and amperage draw. I see I have a four year warranty on the car, don't know if that includes the battery.
Found the battery which is huge and maintenance free ( I assume AGM), I've got it on a charger now & will see what happens. I tried two trickle chargers that plug into the cigarette lighter outlets and neither was making contact ( one was Interstate 1.25 amp, the other an OEM unit 500 mAmp). Maybe you have to buy a M-B trickle charger??
jamesmb is offline
post #5 of 8 (permalink) Old 07-23-2013, 12:32 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
1) the car should enter full sleep mode even if doors were not locked. I doubt other brands need doors locked either, if the cars are OK. You should make sure your phone is not connected to the car via BT (like if the car stays very close to your house) and that the KG keys are not very close to the car.
2) one week or one month should be fine as long as your battery is fully charged when you park the car.
3) at full sleep the battery drain should be less than 80 mA (40 mA on a car that has no alarm).
4) You would only have a very small backup battery for the gear shift control, nothing like the AUX/SBC brakes battery on the W211 or the separate starter battery on cars like R230 and W221 (pre-facelift).
5) MB typically uses AGM/VRLA batteries but some models have lead acid batteries (check the labels at the battery to be sure).
6) the MB branded maintenance charger is made by CTEK but many other chargers are fine too (I'm not familiar with the brands you mention, cannot comment those).
Welcome to the forum!
Diesel Benz is offline
post #6 of 8 (permalink) Old 07-23-2013, 12:39 PM
Quoted: 35 Post(s)
The W212 should not have power on the cigarette lighter when ignition is off. You cannot trickle charge the battery from the cigarette lighter then.
It is quite possible that the car has an intermittent quiescent current issue. Can be difficult to figure out at a garage too, if it is intermittent. The garage however should be aware of quiescent current issues typical to this specific model (at least if they read any of the documents MB provides them).
post #7 of 8 (permalink) Old 07-23-2013, 03:39 PM
Kajtek1's Avatar
Quoted: 1166 Post(s)
I would do the checking as DB pointed.
We had several of our MB parked in carports for 5 weeks with alarms on and they always started on their own power.
Kajtek1 is online now
post #8 of 8 (permalink) Old 07-26-2013, 12:13 PM
Vehicle: 2007 c230 w203
Yes battery draw issues and the vehicle Battery are covered under factory warrenty. But just be aware that they may not find anything right away. Some time these draws can be tricky to find, and have to have the vehicle sit for a day or two while being monitored to find/verify the issue, but the dealer should be able to find it.
j_link is offline
