Bar's head gasket, the right bottle for big damages - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 07-05-2013, 09:22 PM Thread Starter
Date registered: Jul 2013
Originally Posted by TexFinn View Post
Sucks to hear, OP. However, it sounds like you tried using a sledgehammer for a job that could have been done with a tiny hammer.
In other words, you probably had a radiator/coolant reservoir/coolant hose leak, not a bad head gasket.
I would never use those sludges to begin with, but I guess that's beside the point here.
Good luck with your fight, OP. Unfortunately you'll probably achieve nothing.
Hi, no it wasn't that
No hose problem
It was only a little leak, that won't show anywhere during the day.
No coolant spots on the floor, neither at any parking space
The car was running very strong, always a great car on the freeway
But after Bars' was added to the coolant, water circulation stopped completely and no reaching coolant passages, because Bar's liquid became hard as steel and blocked everything on its way
coolduke is offline
post #12 of 14 (permalink) Old 07-05-2013, 09:29 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 875 Post(s)
Originally Posted by Kajtek1 View Post
I would like to see picture of what the sealer clogged in your system if possible?
I have been using sealers in the past on older vehicles and I know they eventually will lower the system efficiency, but never had immediate problem with them.
I posted a link to the current packaging the for the Bar's product #1111 that the OP used.
Noodles is offline
post #13 of 14 (permalink) Old 07-06-2013, 09:30 AM
nathanD.rector's Avatar
Date registered: Jan 2013
Vehicle: 99 s320,and 83 300sd
Quoted: 217 Post(s)
Bars ruint a radiator on me,turned into concrete
1999 s320. and 83 300sd quit driving,people make me nervous
nathanD.rector is offline
post #14 of 14 (permalink) Old 07-09-2013, 04:54 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
I think what must be kept in mind is that Bar and similar products are designed not to fix a problem, but to buy time. How much time depends largely on luck, in my experience.
flyboyike is offline
