'99 E320 temperature issue - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-04-2013, 09:14 AM Thread Starter
Date registered: Jul 2013
hi guys, I have a 99 e320 and I just changed the water pump and the thermostat, the temp gauge runs from 95 to 100 degrees, is that normal? And what could possibly be the issue?
Thanks alot
benz1999 is offline
post #2 of 8 (permalink) Old 07-04-2013, 11:09 AM
Kajtek1's Avatar
Quoted: 1288 Post(s)
Welcome to the forum.
Engine running at 95C with 40F outside would be hot, while with 140F outiside would be expectable.
Is the radiator original? What coolant do you use?
Kajtek1 is online now
post #3 of 8 (permalink) Old 07-04-2013, 03:25 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Thanks alot
What was it running prior to the change, what thermostat did you install and what are the weather conditions?
flyboyike is offline
post #4 of 8 (permalink) Old 07-04-2013, 09:21 PM Thread Starter
The radiator is original, but the coolant is from canadian tire, cheap stuff. the radiator and thermostat are from mercedes and its averaging 23 celcius outside.
benz1999 is offline
post #5 of 8 (permalink) Old 07-04-2013, 09:26 PM
Kajtek1's Avatar
cheap stuff. .
That might be main answer, but did you flush the system doing the job?
15 years old radiator could be neglected before.
post #6 of 8 (permalink) Old 07-05-2013, 05:59 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
There is a version of zerex that will work. A search will tell you which one. I have found that the mercedes coolant from the dealership is not expensive. I would check their prices.
Mike
Michael Pillay is offline
post #7 of 8 (permalink) Old 07-05-2013, 06:03 AM
Date registered: Jul 2005
Quoted: 1117 Post(s)
It is the Zerex G-05 coolant.
Noodles is offline
post #8 of 8 (permalink) Old 07-05-2013, 10:30 AM
Kajtek1's Avatar
Yeah. The stuff that lot of members have in their cars when they post here about overheating problems.
