1981 Mercedes 380 SLC Radio Replacement - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-30-2013, 03:12 PM Thread Starter
TheRookie's Avatar
Date registered: Jun 2013
Vehicle: 1981 Mercedes SLC 380
I am looking for a radio that will replace the original spot of the old one, the old radio was original to the car it was a Becker Radio, Here are the dimensions 182 x 52 x 162mm, and I would like it to be as cheap as possible (No more than $50 in case it doesn't fit) it doesn't have to be anything fancy I just want a working radio, Thanks
TheRookie is online now
post #2 of 5 (permalink) Old 06-30-2013, 03:23 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 164 Post(s)
Radio sizes are standardized worldwide
Any radio that is a DIN size will fit. It is worth your time to also acquire an "installation kit" specific to your car. It will include any required wiring harness and fascia adapters, and instructions. Inexpensive.
A good source for all that stuff is Crutchfield through thier web site.
rocky raccoon is online now
post #3 of 5 (permalink) Old 07-01-2013, 12:33 AM
Date registered: Jan 2009
Vehicle: anywhere from '52 300 to 1990 560SEL,and a '93300TE nothing newer, too much trouble....
Quoted: 11 Post(s)
If you could fill in details of where you are....
I have several option for you.
Alex
6punkt3 is offline
post #4 of 5 (permalink) Old 08-15-2013, 08:15 PM Thread Starter
TheRookie's Avatar
I bought this- http://www.amazon.com/gp/product/B007B631RA/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
I couldn't find an installation kit, but this one fit perfectly, my only problem is that the radio doesn't remember my presets or the time, its supposed to as advertised on the box, any suggestions?
post #5 of 5 (permalink) Old 08-18-2013, 12:10 PM
Davidshrn's Avatar
Date registered: Jul 2013
Vehicle: 1993 Mercedes 300E
The presets and clocks are wired direct to the hotwire. It's been several years since I have messed with car stereos, if I remember right the stereo should have had 2 wires for power. The one for the radio connected to the usual power source from fuse block. It is set up so when you turn car off the radio shuts off.
The other wire was for the radios memory i. e. presets/clock, it usually was connect to Hotwire under the dash going to ignition system.
Like I said its been a 15 years or more since I have messed around with radio installations so things have probably changed. Check the radio's installation manual and if you can't find the answer there call your local car audio store. They can tell you exactly what to look for.
Davidshrn is offline
