P0700 code - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-27-2013, 07:39 PM Thread Starter
Date registered: Jun 2013
Vehicle: 1998 E320 W
P0700 code
My 1998 E320 just started to have transmission issues. I noticed it not shifting properly when I came to a stop light. When I tried to go on the green the engine raced as though it was in neutral and then it started to grab a little for forward momentum but it didn't shift properly. It was at that time that the check engine light came on along with Engine Electronics in the read out area. The yellow triangle light was flashing at that time as well. I limped home and each time I came to a stop light I had to turn off the car and let it set for about 10 seconds and then restart and it would go up to around 40 mph and the yellow triangle would flash and the engine would slow down. At last I had a friend come over to the house with his little code machine and we got the P0700 code. Here's the question, is this something I can do myself,(I'm pretty handy) or does it need to be taken to a good shop? Any past experience with this kind of problem? I await the vast knowledge and experience of you gurus. Thank you.
GarthsMB is offline
post #2 of 2 (permalink) Old 06-28-2013, 05:39 AM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 876 Post(s)
P0700 is a fairly generic trans code. A more advanced scanner would have shown more detailed codes. Unless you have has experience with repairing the 722.6 transmissions I advise to get the codes fully read and then you will know what you are facing. It could be a bad solenoid or conductor plate.
The trans my have worn out a clutch pack. If you look in the W210 section on the forums here there is a whole sticky thread about the transmission.
Noodles is offline
