2002 CLK 320 Avantgarde 70K miles - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-22-2013, 01:21 AM Thread Starter
Date registered: Jun 2013
Post 2002 CLK 320 Avantgarde 70K miles
Hi everyone from South Wales in the U.K. (new member)
Can anyone advise please in relation to a wiring loom containing two wires (1x brown/white and 1x brown) which are soldered into a removable connector/plug below the front passenger seat.
There is an identical one below the drivers seat.
The seats are electrically operated and working perfectly and there is also a separate wiring loom with 6 ? wires and a connector/plug below each front seat which I believe is for operating the respective seats.
The two wires (brown and brown/white) were found to have become disconnected from their soldered joints in the connector/plug in) I was unable to identify which was connected to which.
The wires were dificult to access and solder in place so I resoldered two wires onto the plug with the intention of crimping and joining the existing wires.
What I would like to know is what function does this plug/connector have and the importance of connecting the correct wires.
Is this some form of a switch wire for an air bag ? (if so how does it work)
What would happen if I reverse connect these wires ?
What tests should I carry out if any ?
I do not have heated seats.
Many thanks.
SG02 is offline
post #2 of 3 (permalink) Old 06-22-2013, 02:20 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld, I can tell you the wires are not for SRS/Airbag as all those wires are yellow. But for best results post your question on this link;
W208 CLK Class - Benzworld.org - Mercedes-Benz Discussion Forum
eric242340 is offline
post #3 of 3 (permalink) Old 06-22-2013, 08:39 AM Thread Starter
Many thanks wil try that.
SG02 is offline
