new member urgent help needed - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-12-2013, 08:57 AM Thread Starter
Date registered: Jun 2013
Vehicle: slk 230
Hi all ,member here. I have a 1998 slk 230 with 53000miles onthe clock.
I purchased the car last year and noticed a couple months after that the engine would cut out whilst driving it, however it would re start after a couple of minutes and inever thought much of it.
the problem has got much worse of late and now wont start for days when it does cut out, and it is cutting out very frequently.
Ive read a few topics on here and have folowed some of the advice. I have spent over £500 and have not solved the problem, mymechanic can not solve the problem and neither can my local mercedes benz dealership.
The car will work fine one day, but not start atall the next.I will be driving along and all of a sudden it will just cut out on me, the roof will go up and down and all the electrics will work, the fan comes on but just wont start.
ive took advice on here and replaced the crankshaft sensor, had a new alternator fitted, had the k40 relay sensor out (appears to be in perfect condition ). mercedes benz have had the car 3 weeks and said that no fault codes are showing up, they tell me it could be the k40.
I am at my wits end and am just spending money and getting nowhere, could anyone please help me out with some advice or has anyone had the same problem?.
All feed back greatly appreciated, many thanks kurt .
giftedk is offline
post #2 of 10 (permalink) Old 06-12-2013, 09:20 AM
I had a similar problem with my S-class. It just died while in drive and luckily I was in my drive way. I had towed it to my local garage and they found the problem and fixed it for around $150. I was happy it wasn't something major. The only problem is I don't remember which part it was that was replaced. I will look for my receipt to look at the part replaced. I should have it close by because I just took all of my paper work out of that car because I traded it in. I will get back to you on that.
Osiris21 is offline
post #3 of 10 (permalink) Old 06-12-2013, 09:47 AM Thread Starter
Vehicle: slk 230
If you could tht would be great. thanks osiris21 .
giftedk is offline
post #4 of 10 (permalink) Old 06-12-2013, 02:19 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome; please click user cp and edit details so you can add your vehicle and location to your profile, that's often useful information when you're seeking assistance.
Also, please note that you are posting a request for help on a specific model in the new member forum...which is really just a place to say "Hi, I'm here."
For help with a specific car, it's best to search and post in the forum specific to the car, in this case the R170 forum.
And if you do so, I think you'll find that the K40 relay should be regarded as a chief suspect. It may just need to be resoldered, and there are youtube videos on how to do that.
Good luck.
Check Codes is offline
post #5 of 10 (permalink) Old 06-13-2013, 02:04 AM Thread Starter
Vehicle: slk 230
many thanks checkcodes, i have reposted it on there. I have a freind across the rd who is an electrician, he tested the k40 nd said it was working fine and there is now obvious sighns of dmage when i look t it .
thnks again .
giftedk is offline
post #6 of 10 (permalink) Old 06-13-2013, 02:32 AM
eric242340's Avatar
Quoted: 306 Post(s)
Welcome to Benzworld, does the fuel pump get a signal when this engine will not start?
ERIC.
eric242340 is offline
post #7 of 10 (permalink) Old 06-13-2013, 05:06 AM Thread Starter
Vehicle: slk 230
hi eric242330 and thanks for the reply . I may sound dumb but how do i tell if the fuel pump gets a signal when it wont start, and if not what would that mean?.
many thanks
giftedk is offline
post #8 of 10 (permalink) Old 06-13-2013, 05:23 AM
eric242340's Avatar
Quoted: 306 Post(s)
many thanks
Well you are obviously not the diy car mechanic type, do you have a friend who can help you with this, a diy type or a mechanic?
ERIC.
post #9 of 10 (permalink) Old 06-14-2013, 01:15 AM Thread Starter
Vehicle: slk 230
hi eric . yes i have a local mechanic and he fitted a crankshaft sensor, he could help me if i was toknow what imlooking for.
many thanks
giftedk is offline
post #10 of 10 (permalink) Old 06-14-2013, 01:30 AM
eric242340's Avatar
Quoted: 306 Post(s)
many thanks
Well he obviously thought cps to start with, the signal for the pump starts with the cps. The new cps may be a cheap one, there are lots on the market so to test this we need to know if the engine is getting fuel, ask him if the engine is getting fuel.
ERIC.
