WIS installation: error code 42, attach database fail - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-12-2013, 08:25 AM Thread Starter
Kilek's Avatar
Date registered: Feb 2011
Vehicle: S320L 2002
Send a message via Skype™ to Kilek
Install of WIS on Windows 7 (32bits) fails at Test new database. I get "Installation of the WIS database has failed!" error and log shows "Error in attaching ROM files to database file "_TMP__wisnet" in to WIS net Transbase! Error code was 42."
Ewa admin is set to run in compatibility mode of WinXP SP2 and as an admin. EWA and EPC are installed and functional.
Log shows this, error popup attached:
Code:
Information at 12:42:59 :  CMD: C:\Program Files (x86)\EWA net\database\TransBase WIS\tbadm32.exe -Cf _TMP__wisnet h=C:\Program Files (x86)\EWA net\database\Database WIS 1\test\_TMP__wisnet cp=propriet u=254 nc=16*1024 lc=16384 d=,2000000 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R2\rfile002 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R1\rfile001 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R0\rfile000 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R8\rfile008 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R5\rfile005 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R4\rfile004 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R3\rfile003 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R7\rfile007 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R6\rfile006
Warning at 12:43:29	:  Process did not finished within 30000 milliseconds. Killing it ...
Warning at 12:43:29	:  Query process successfully killed
Information at 12:43:29 :  Because the process has been destroyed, try again to execute ...
Error at 12:43:29	:  Error in attaching ROM files to database file "_TMP__wisnet" in to WIS net Transbase! Error code was 42.
Warning at 12:43:29	:  Executed command was: C:\Program Files (x86)\EWA net\database\TransBase WIS\tbadm32.exe -Cf _TMP__wisnet h=C:\Program Files (x86)\EWA net\database\Database WIS 1\test\_TMP__wisnet cp=propriet u=254 nc=16*1024 lc=16384 d=,2000000 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R2\rfile002 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R1\rfile001 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R0\rfile000 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R8\rfile008 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R5\rfile005 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R4\rfile004 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R3\rfile003 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R7\rfile007 rf=C:\DB\WIS\wisnet\121213231237___G_01_13\R6\rfile006
Error at 12:43:29	:  Not all database files in WIS net Transbase were attached successfully!
Information at 12:43:29 :  Start deleting database
Thanks for any ideas.
Kilek is offline
post #2 of 8 (permalink) Old 06-12-2013, 11:12 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
On WIN7 you should not need other additional actions but turning UAC off and run the installation with admin rights. If this fails, perhaps your DVDs are not good.
Diesel Benz is offline
post #3 of 8 (permalink) Old 06-12-2013, 01:22 PM Thread Starter
Kilek's Avatar
Vehicle: S320L 2002
Thanks, I have read that UAC off is needed just for DAS. For WIS and EPC it should be ok confirming each action. However with UAC on or off I get the same result. EPC installs, WIS does not.
Kilek is offline
post #4 of 8 (permalink) Old 06-12-2013, 04:48 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160
Quoted: 496 Post(s)
Open the EWA Admin Tool and re-install the WIS database.
If that doesn't work, run the VBS script to clean the install and start all over again, but use the EPC disc to install the EWA software.
DrX is offline
post #5 of 8 (permalink) Old 06-12-2013, 06:16 PM
Date registered: Jul 2005
Quoted: 1087 Post(s)
It is not a UAC issue for WIS or Win 7 issue. The latest WIS is written to install and run on Win 7.
His source data from the installer is corrupt.
Noodles is offline
post #6 of 8 (permalink) Old 06-12-2013, 10:44 PM
Quoted: 39 Post(s)
I've only installed these on WIN7 and never needed the VBS script but I've understood it would not work on WIN7 any more.
The advice to install EWA from the EPC DVD is well known but I've done it several times starting from WIS DVDs and never had problems. Does not harm to do it from EPC though, perhaps solves a rare case that I have not faced.
post #7 of 8 (permalink) Old 06-14-2013, 03:38 AM Thread Starter
Kilek's Avatar
Vehicle: S320L 2002
Vbs does not work for me on Windows 7. Ewa commands /cleanwis, /cleanepc do work.
I was not able to install Ewa from EPC disks so far. Installing Ewa from WIS, then installing EPC, then WIS leads to same error for WIS. EPC and Ewa runs fine.
Kilek is offline
post #8 of 8 (permalink) Old 07-20-2013, 12:04 PM Thread Starter
Kilek's Avatar
Vehicle: S320L 2002
WIS DVDs, or this version was corrupted. Installing different WIS db solved the issue. Thanks to you all
Kilek is offline
