How Do You Remove These Hoses? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-09-2013, 10:12 AM Thread Starter
Date registered: Jan 2008
Vehicle: 1981 380sl
Quoted: 15 Post(s)
As I'm in the process of taking my AC system apart, I was wondering if anyone knew off-hand the size of the large nut on the AC hose in the attached photo? The largest open-end wrench I have is 7/8, and that's to small.
In addition, I was wondering what the best way was to loosen that nut and the one in the other photo without over-stressing anything, as I can't seem to get a counter-hold on anything in the second photo?
DO they usually have to be torched to loosen them?
Thanks in advance.
Bill
Name:	AC hose 2.JPG
ID:	520406   Click image for larger version
Name:	AC Hose 1.jpg
mbboy is offline
post #2 of 4 (permalink) Old 06-09-2013, 01:00 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1340 Post(s)
That is probably 24 mm.
You need 2 wrenches to hold opposite parts. I fit the wrenches so there is small angle between them and then squeeze them together with palm of my hand.
Beware those are soft connectors so make sure you have well fitting wrench to not round up the corners.
Kajtek1 is online now
post #3 of 4 (permalink) Old 06-09-2013, 02:17 PM Thread Starter
Vehicle: 1981 380sl
Quoted: 15 Post(s)
Thank you. Someone in another forum said it was 27mm. So, I'm still not sure which one to get? Or could it be that one of you is talking about one of the nuts, and the other is talking about the other nut
In the 2nd photo, is it the big nut or the little nut that turns?
mbboy is offline
post #4 of 4 (permalink) Old 06-09-2013, 05:08 PM
Kajtek1's Avatar
You should buy a set and flare wrenches are advisable.
If you have Harbor Freight Tools near by they sell them pretty cheap and decent quality.
Don't you have metric tape measure or scale?
