2002 ML320 Air Conditioning System Problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-07-2013, 11:36 AM Thread Starter
Date registered: Feb 2010
Vehicle: 2002 ML 320
I own a 2002 ML 320 with 211,000 miles. V6 Engine all wheel drive.
I have replaced a few things on this vehicle but nothing major:
  • Alternator
  • Water Pump
  • Belt Tensioner
  • Power Steering Pump
  • Both up-stream O2 Sensors
  • Outer Tie Rods
  • Valve Cover Seals
  • Rotors/Pads
  • Fuel Filter
  • Air Filter
You get the drift. Easy Maintenance Items.
I would really love some help figuring out why my A/C cuts out.
  • Hi-Side Pressure is fine. Fully Charged.
  • After starting the car the air conditioner is working and then quits at different intervals. It is never the same.
  • Almost each time I restart though the A/C turns back on about 95% of the time but then quits again after anywhere between 10 and 30 minutes of driving.
  • RPM's are steady at idle
  • Outside Temperature Reading on the dash is usually accurate
  • Blower Fan works whether it is blowing a/c air or not.
  • I don't here any weird noises coming from the blend door actuator
  • I also cleaned up the electrical connection to the A/C Compressor
Does anybody have any ideas?
derekalldaffer is offline
post #2 of 2 (permalink) Old 06-07-2013, 06:45 PM
eric242340's Avatar
Quoted: 309 Post(s)
Welcome to Benzworld, the forum for questions on your model is;
W163 M-Class - Benzworld.org - Mercedes-Benz Discussion Forum
ERIC.
eric242340 is offline
