'99 E320 (210) thunk - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-27-2013, 01:20 PM Thread Starter
Date registered: Jan 2010
Car emits a solid thunk under strong acceleration from a standing stop.
Engine/tranny mount?
I first thought it was steering as I had a worn tie rod but it still thunks after I replaced the rod.
Any particular procedure to follow to check the mounts?
If one is bad should I replace 'em all or only the bad one?
As far as I know, they are all original.
1999 E320
1994 F150 (awaiting new engine)
1989 560 SL
1986 560 SL (deceased)
1988 300 TE (departed)
1994 945T (daughter's)
1986 242Ti (fallow)
1968 GT500KR (under restoration)
bob k is offline
post #2 of 2 (permalink) Old 04-27-2013, 06:42 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
Yes, most likely the engine mounts. Pretty common. Open the hood and power brake it , im sure you know how to but just in case you don't, hold brake, put into driver and gas it while holding the brake. When your in drive you will see the left side of the engine "jump" up. Do the same in reverse and this will check the right side mount. You will actually see the engine pop up if they are really worn. I would replace both and the trans mount as well.
saleen1276 is offline
