Help needed to get my 2001 clk convertible started - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-15-2013, 01:52 PM Thread Starter
Date registered: Apr 2013
So heres the story bit by bit, hoping some of you very smart Mercedes Benz Gurus can help me get the 2001 430 clk started. If you could even answer some of the questions it would be greatly appreciated.
I bought this wrecked 2001 430 clk convertible with 80k miles on it , Other than the front end damage it’s a pristine car. Serviced regularly ,and easily driven,and it’s a beautiful car.
I replaced the front frame clip, fenders, hood , radiators, fans, waterpump, lights, and everything needed to get it back on the road, still need some parts but hey.. it’s a project . its to a point I need to start it up and service the motor and do other things.
I charged the battery, reset the computer, and most things work(windows, locks,trunk, lights,)
The convertible top doesn’t go down tho,
and the starter wont engage
Im sure it will run but I’m Bummed now,
The questions I have now are this,
The Key, It’s the right key because the locks unlock, trunk works, sterring unlocks when its put in the ignition, lights on dash comes on and looks like its ready to start. Seems like the brake switch may not be working(push brake to start)??? Wheres the switch and can it be bypassed for a test???
Trans needs to be in park…Wheres the switch and can it be disabled to test??? Bad switch??
The roll bars are up I think, I read somewhere they need to be reset ,switch on dash wont do anything, With the rollbars being up, will it stop the starter from engaging?? Is there a way to manually reset the rollbars??
Starter relay fuses??? Read something it could be #51, 54, 44 …cant find them to look(looked left of steering wheel, trunk, and under hood),no fuses of that #, and wheres the relay??
I still need the fan shroud ,so I havn’t filled the car with fluid,(water in the raditor only) Can there maybe a censer telling the computer theres no water in it, and not let the starter engage .
Could it be the starter selinoid???
I have pulled out my hair on this one,Im tired, frustrated, puzzled and disappointed in this project now and need some help, Can anyone help????
Thanks Dan
dan84v is offline
