How can u disable an ML so it can't be started? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-09-2013, 08:26 AM Thread Starter
I have an ex-gf who has a key to my '08 ML, who I am afraid may try to drive off in. Is there an easy way to disable the ignition or some type of connection that will easily prevent this from happening? Thanks so much if you can suggest anything!
Mango7 is offline
post #2 of 10 (permalink) Old 04-09-2013, 09:02 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If she won't give you the key back, go to the dealer and tell them what happened. They can look at your key (that you want to keep) and then disable the other one so it will no longer work with the vehicle. They can also order a new key for you so you'll still have two, and I'd highly encourage that, since if you lose your other one it's lots more painful and expensive to get another.
Good luck.
Check Codes is offline
post #3 of 10 (permalink) Old 04-09-2013, 11:00 AM
Triggerhappy's Avatar
Date registered: Nov 2009
Vehicle: 1978 240D
Quoted: 41 Post(s)
Pull some circuit breakers. You can even disable the ignition so that the engine turns over but won't fire.
Triggerhappy is offline
post #4 of 10 (permalink) Old 04-09-2013, 11:39 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Have you asked for the key back? I would and document the time and what was discussed. I am not sure where you live but you can inform your local police that there is an individual who has a key but has no legal standing to have the vehicle. Grand theft auto is pretty serious. If she does drive away in it, file criminal charges.
Mike
Michael Pillay is offline
post #5 of 10 (permalink) Old 04-09-2013, 04:53 PM Thread Starter
Thank you very much, CC!! Will look into doing
Trigger- this is also a great idea but don't know which fuse to pull. Thanks tho!!
Hi Michael. If she does snatch it before I can disable, I will certainly file crim charges. Thank you
K
Mango7 is offline
post #6 of 10 (permalink) Old 04-09-2013, 06:52 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
In the mean time I would pull fuel pump fuse.
Kajtek1 is offline
post #7 of 10 (permalink) Old 04-10-2013, 08:17 AM Thread Starter
Thanks Kaj! Good idea
Mango7 is offline
post #8 of 10 (permalink) Old 04-12-2013, 01:34 PM
Date registered: Feb 2012
Vehicle: 2003 ML500, 2003 SL500, 2007 S600 Designo, 2016 E400
Quoted: 16 Post(s)
Don't spend any money to replace keys, or any time to disable and reenable it everytime you want to drive it. Call her up and demand the key back, if she refuses then hang up and call the police. Why would you even consider letting her win by making you spend money and time on being afraid of what she will do? You are letting this woman walk all over you and you need to take control.
mmiller619 is offline
post #9 of 10 (permalink) Old 04-12-2013, 02:15 PM
Quoted: 35 Post(s)
Great advice when you know absolutely nothing of the situation.
She may be a psycho and come after him -- or perhaps she is suicidal and would off herself. Maybe the OP is just non-confrontational. Why not let him handle *her* in the manner he deems most appropriate?
post #10 of 10 (permalink) Old 04-18-2013, 10:40 AM Thread Starter
Thanks Gents. Its a contorted story but I will let u know more details after some time elapses. Thank you again!
Mango7 is offline
