how to remove & clean *suspension body valve* on cls 55 amg - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 04-04-2013, 05:59 AM Thread Starter
Date registered: Mar 2013
hi everyone hope you all are well
i wanted to know how to remove the body valve which is connected to the airmatic compressor on a cls 55 amg
i have uploaded a sample picture of a mercedes body valve up
i dont know if the car needs to be connected to STAR while doing this or does it need calibrating after putting back together.
my rear driver side is sagging diagnostics comes back ok no leaks ,my mechanic wants to charge around £1500 to to replace but was told it can be removed and cleaned which may fix the falut
any step by step guide out there from WIS...?
really would appreciate it
updated with correct picture
cls-55amg is offline
post #2 of 24 (permalink) Old 04-05-2013, 03:58 AM
eric242340's Avatar
Quoted: 309 Post(s)
The valve you posted is not for Airmatic, it is for ABC so which system do you have, ABC or Airmatic and if ABC is this the rear valve?
ERIC.
eric242340 is offline
post #3 of 24 (permalink) Old 04-05-2013, 04:08 AM Thread Starter
hi eric sorry its the airmatic not ABC i just googled a general picture of a body valve for everyone to have a rouch guess which part i am on about but like you said i got the wrong pic :S
the mechanic said its at the front left next to the compressor
post #4 of 24 (permalink) Old 04-05-2013, 04:22 AM
eric242340's Avatar
Quoted: 309 Post(s)
Your mechanic is correct, but do not waste your time trying to clean it, this in my experience never works. The pump has to be removed to replace the valve, I can give you the whole procedure if your mechanic does not know how to do it.
ID:	507268   Click image for larger version
ERIC.
post #5 of 24 (permalink) Old 04-05-2013, 04:35 AM Thread Starter
hi eric i would really appreciate that.
does the car need to be on STAR to calibrate the suspension or can i just pull this off and not worry....?
last thing i want the car to drop on my mechanic
post #6 of 24 (permalink) Old 04-05-2013, 04:39 AM
eric242340's Avatar
Quoted: 309 Post(s)
This operation should be carried out on a wheels free lift to prevent injury, naturally once the pipes are disconnected the car will drop albeit slowly.
Or he could do it with the front end up and on axle stands.
As for calibration, it is not always required only sometimes, so it is pot luck there.
ERIC.
post #7 of 24 (permalink) Old 04-05-2013, 04:41 AM Thread Starter
i think this is the part i require
post #8 of 24 (permalink) Old 04-05-2013, 04:42 AM
eric242340's Avatar
Quoted: 309 Post(s)
Yup, one pipe goes to the central reservoir and the other four to the struts.
ERIC.
post #9 of 24 (permalink) Old 04-05-2013, 04:44 AM Thread Starter
that makes sence
i will have to get the car on front axle stands
post #10 of 24 (permalink) Old 04-05-2013, 04:46 AM Thread Starter
brilliant
do you have a step by step guide on how to do this Sir...?
i really appriecate you helping me i only just bought my cls 55 and upsetting to see her sagging on one side when car is in sleep mode
i have had diagnostics and it came back ok no leaks
just this next step then if no luck i will sell the car
