C220 cdi no crank - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-26-2013, 08:39 AM Thread Starter
Date registered: Mar 2013
Unhappy C220 cdi no crank
Hi,I have a 2003 220cdi coupe that won't crank,I've read on the forum about it could be low battery,I've just fitted a brand new battery and still no crank,dashboard lights up with no problems glow plug light goes out but engine will not crank over,I've tried the spare key but still the same it moves from park when the ignition is on and I've checked all 3 points on the car for broken fuse's,has anybody got any idea of what the problem could be.
Regards John
savage_996 is offline
post #2 of 3 (permalink) Old 03-27-2013, 01:56 AM
eric242340's Avatar
Quoted: 296 Post(s)
Welcome to Benzworld, it may be the EIS (Electronic Ignition Switch) use a hair dryer to warm the area around the switch and see if this works, I believe it is rather cold in UK at the moment and the EIS can be affected at low temps.
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 03-27-2013, 09:11 AM Thread Starter
Hi and thank you to those that replied,had the auto electrician out today and the car is now working,turned out to be a stuck solenoid on the starter.car now back to starting as it should.
Regards John
