brake lite switch - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-25-2013, 08:13 PM Thread Starter
Date registered: Nov 2011
Vehicle: 2002 cl600
brake lite switch
i know a bad brake lite switch can cause codes to come up, but can it also cause speedo to stop at same time thanks
BADBENZ500 is offline
post #2 of 6 (permalink) Old 03-25-2013, 11:05 PM
Date registered: Jul 2005
Quoted: 1011 Post(s)
It should not.
Noodles is offline
post #3 of 6 (permalink) Old 03-26-2013, 12:01 AM
Kajtek1's Avatar
Quoted: 1195 Post(s)
I guess when it gets too lite, it might?
When it comes to brake light switch, no it will not trigger the code, unless something changed in new cars. The ESP or ASR light will come.
Kajtek1 is offline
post #4 of 6 (permalink) Old 03-26-2013, 05:46 AM Thread Starter
Vehicle: 2002 cl600
Dealer told me I had a bad ESP module can that cause speedo to stop working. My problems are intermittent Speedo,ESP,abs,bas and no shift happen at same time. They want 2100.00 to replace ESP module. Thanks for your input
post #5 of 6 (permalink) Old 03-26-2013, 08:33 AM
Kajtek1's Avatar
What car?
Dealers always do something like that and then "wash their hands" when the $2100 module did not fix the problem, but $70 sensor did.
I would look for indy with Star level computer to get second opinion. In the mean time cleaning and checking wheel senors as well as axles "gears" would be good idea..
Kajtek1 is offline
post #6 of 6 (permalink) Old 03-26-2013, 08:58 AM Thread Starter
Vehicle: 2002 cl600
2000 s430. Thanks for all ur help I try cleaning eveything and go from there. Nothing worse than intermitant troubles. Thanks again
