1998 c250td starting problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-22-2013, 07:46 AM Thread Starter
Date registered: Apr 2009
Hello all
I have just bought a c259 td when its cold in the morning I turn the key and wait for the pre heat light to go out and it will start first turn of the engine, I reverse out of my garage stop the engine and leave it half an hour go through the same procedure and it will not start, if when its going I warm it up to running temp its fine all day, I,ve just fitted new glow plugs and its still the same, any advice please
Just tested the voltage at the glow plug end of the wire and its only 10.5 volts can you get a new wiring harness anywhere
rupert4 is offline
