NEED HELP QUICK! 2002 c230 coupe serpentine belt tensioner pulley bolt moves? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-16-2013, 11:31 AM Thread Starter
Date registered: Jan 2012
Vehicle: 2002 c230 kompressor 6 speed
I removed the tensioner pulley off the main belt because the bearing went bad and its clunking (not the supercharger belt). I noticed the bolt moves in and out freely after I removed it..is this normal? its the main bolt with 15mm nut that holds the pulley in place..is the entire tensioner shot? or is this normal? thank in advance
hayez is offline
post #2 of 7 (permalink) Old 03-16-2013, 01:45 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Pictures?
Posting the question in your model section might give you more accurate answer, but if your belt is playing around the pulleys, I would not drive the car like it.
Even the belt is cheap, quite often when it goes it can take fan fins and radiator with it.
Kajtek1 is offline
post #3 of 7 (permalink) Old 03-17-2013, 01:24 PM Thread Starter
nobody ever goes in there and i was hoping to get a answer before i replaced it in the am. ill get a pic now
hayez is offline
post #4 of 7 (permalink) Old 03-17-2013, 02:55 PM Thread Starter
cant get a good pic..but the pulley is taken off and the main bolt that held the pulley on moves in and out of the tensioner apprx 1/2 inch freely..is this normal? im going to replace the pulley in the am if anyone has any advice..thanks
hayez is offline
post #5 of 7 (permalink) Old 03-17-2013, 06:12 PM Thread Starter
anyone got any info?
hayez is offline
post #6 of 7 (permalink) Old 03-17-2013, 08:36 PM
Date registered: Jul 2005
Quoted: 1118 Post(s)
I do not know the engine well, but if you are talking about the bolt that attaches the tensioner to the engine it should not have any play at all.
If it is the axle the tensioner pulley rides on it should not have any play. If it is the idle pulley (assuning this engine has one) it should not have any play either.
Noodles is offline
post #7 of 7 (permalink) Old 03-18-2013, 12:43 AM
Date registered: Mar 2013
hufqnjhu is offline
