1988 420 sel charging issues - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-11-2013, 07:30 PM Thread Starter
Date registered: Dec 2008
I have a 1988 420 that intermittently will not charge the battery. I replaced the alternator, regulator and the battery. The battery light on the dash has never come on. It also does not come on when the key is tuned to the run position (the lights next to it do not come on either). Checked the lamps and the connections at the dash and they are all good.
Pulled the new alternator and the battery and had them tested. All good.
I found a bad ground strap on the drivers front side of the engine and replaced.
Is there a relay that controls the lights on the instrument panel? I know that the charging light circuit must be complete to make the alternator work.
Any suggestions would be appreciated.
windycity is offline
post #2 of 2 (permalink) Old 03-16-2013, 02:43 AM
Date registered: May 2005
Vehicle: W123, W116 Wagon
Check all fuses
npk is offline
