2003 - 2005 suspension question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-16-2013, 03:56 PM Thread Starter
eps930's Avatar
Date registered: Feb 2013
Vehicle: 2004 SL500
Quoted: 2 Post(s)
I am new to this fourm as well as Mercedes. I plan to buy a 2003 to 2005 SL500 (Am still looking if anyof you may have one for sale)and have read the horror stories per their air suspension failures.
My question to you folks is: Can the shocks be replaced with Non-Air system shocks. If so can anyone guide me to source as I have not yet found anything. I can fabricate some parts if necessary.
Thanks - EP Slick - Tucson
eps930 is offline
post #2 of 3 (permalink) Old 02-16-2013, 08:43 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 884 Post(s)
Have no fear. A site sponsor called Arnott Industries makes lifetime warranty replacements that are over 65% less than the dealer price for the year and model you are looking at.
Noodles is offline
post #3 of 3 (permalink) Old 02-20-2013, 08:14 PM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
well, it all depends. Most of the R230 SL vehicles have ABC and not Airmatic. ABC stand for Active Body Control. They do not use air. Instead, they use hydraulic fluid. They do have a steel spring inside the shocks, but the height and drivablility of the vehicle is controled by the hydraulic portion of the shock. It is quick to work and these vehicles do not have sway bars, since the amount of pressure is regulated and it stabilizes the vehicle using hydraulic pressure. So you don't have to worry about air leaks, only on your tires. Downside on this is that ABC parts are more expensive than Airmatic.
If I were you, look for a 2007 and newer SL. The earlier have a brake by wire system called SBC. It is an awesome braking system, but it does have a service life and the hydraulic unit is 1500 to 2000 dollars and you need special equipment to put this system into service. The later model R230 SL have a brake system called ABR and it is good and not as prone to have issues as SBC.
OzzyQ80 is offline
