1989 300SE Clutch not engaging on compressor - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-07-2013, 05:28 PM Thread Starter
Date registered: Jan 2013
Hi all, this is my first post. So apoligies if i have posted it in the wrong area. Iíve only just bought my first a 1989 300SE Mercedes. I just recently joined the Mercedes car club Victoria, Australia and looking forward to taking her out on some club runs once I have fixed a few little issues. Everything on the car works well except for the air con. I checked last night and can confirm that when I turn the A/C ON, the compressor clutch is not activating. The question I have is, if the car is low on A/C gas which Iím nearly 100% sure it is, does this prevent the compressor from switching ON via a small sensor? Everything else works well; fan, heater etc all good and it will blow normal cold air from outside no problems. I can also confirm that the car has been switched over to run the current gas and does not run on the old type.
Aaronwl is offline
post #2 of 2 (permalink) Old 02-07-2013, 06:44 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
Yes being low on refrigerant will send a signal to shut down the engagement of the compressor. A good Air Con shop can charge it up with gas and a UV dye to make sure there are no leaks. If it leaks obviously you will need to fix the leaking part(s).
Welcome to Benzworld!
Noodles is offline
