best way to improve gas milage on 99 ml430 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-31-2013, 06:40 AM Thread Starter
Date registered: Jan 2012
Vehicle: 2002 c230 kompressor 6 speed
any tips? 156k no check engine lights on, car is all stock
im averaging 15mpg right now as a mixture of city/fwy
hayez is offline
post #2 of 9 (permalink) Old 01-31-2013, 08:41 AM
Date registered: Aug 2008
Vehicle: 2000 CLK 430 Cabriolet 2003 S500 4Matic 2004 S55 2005 CLK 500 Cabriolet 2008 S 450
Quoted: 63 Post(s)
Pump the tires up to maximum if mileage is so important. The ride will be horrible but you will see an incre4ase in gas mileage. You're driving a door (coefficient of friction) and can never expect good gas mileage. IMO
mrbobby is offline
post #3 of 9 (permalink) Old 01-31-2013, 09:40 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Driving technique can be the biggest fuel saver. Try driving at 50 mph and you will be shocked.
Kajtek1 is online now
post #4 of 9 (permalink) Old 02-02-2013, 02:33 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
I would do a search on the w163 forum to see if your vehicle needs the fuel line and filter retrofit. My ML320 did. The gas mileage went up a bit after that. I probably still get around 17mpg so for your ML430, 15 mpg might not be too far off. I have a heavy foot though.
Mike
Michael Pillay is offline
post #5 of 9 (permalink) Old 02-02-2013, 02:50 PM
Date registered: Jul 2005
Quoted: 1117 Post(s)
I get 18-21 hwy and 16-17 around town.
Last 1500 miles has been a combined of 18.3 for the ML 430.
Factors like tire rolling resistance, ignition condition, fuel system condition, RFG fuel if mandated in a specific area. That RFG with 10% ethanol is horrible.
Noodles is offline
post #6 of 9 (permalink) Old 02-02-2013, 08:18 PM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
Have you thought about a Prius??????
OzzyQ80 is offline
post #7 of 9 (permalink) Old 02-02-2013, 08:23 PM
LOL just kidding
Well, simple checks like tire pressures, clean filters, good spark plugs and cables, and just basic maintenance can help out with providing better gas milage. And believe it or not, i hope you don't have aftermarket wheels. Unsrpung weight also adds to decreased fuel economy. What doesn't help out now a days is the 10% ethanol/90% gasoline mixutre. Ethanol burns quicker and provides less power also.
OzzyQ80 is offline
post #8 of 9 (permalink) Old 02-03-2013, 05:38 AM
Quoted: 91 Post(s)
:0
That's the other side of the car spectrum! The best gas mileage I have been able to get was 22mpg. That is with the family packed in along with all the luggage for summer vacation. Gassed up at once we entered Ohio. Drove speed limit on fairly flat ground (dont speed in Ohio!)
Gas mileage went done in West Virginia. Driving those inclines worked the old girl out.
Mike
post #9 of 9 (permalink) Old 02-03-2013, 12:37 PM
Triggerhappy's Avatar
Date registered: Nov 2009
Vehicle: 1978 240D
Quoted: 41 Post(s)
As others have mentioned, the top things you need to do are:
1) Drive slower. This makes the biggest difference, by far. Accelerate slowly at lights and keep it to the speed limit. Don't use cruise control. Your gas mileage can vary up to 10mpg (from personal experience) depending on how you drive.
2) Fill your tires to just under sidewall pressure. It may affect safety and ride but it will make a 2-4mpg difference in gas mileage.
3) Stop using ethanol gas! Get the good stuff, 93 octane pure gasoline. Another 3-5mpg difference.
4) If you haven't already - keep up on regular maintenance. Change the air filter and the oil. Depending on how dirty they are this may add another 1-2mpg.
Things not to worry about:
Air conditioning. It makes no difference.
Shedding weight. Unless you are carrying around hundreds of pounds of crap it isn't going to make a difference. The weight of the spare tire won't affect your gas mileage at all.
Fuel additives - no, just no.
Triggerhappy is offline
