95 e320 broken key in ignition car in park!!!! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-28-2013, 09:02 AM Thread Starter
Date registered: Mar 2012
Vehicle: 1995 E320
Broke a key off in my e320 and someone swore he could fix it. Bought new lock and key. He frigging cut the lock Shields( which now I found). The cat starts and won't switch into any gears. HELP!!!! Can you explain how this works....
Sent from my SPH-D710 using AutoGuide.Com Free App
Spicealata is offline
post #2 of 2 (permalink) Old 01-28-2013, 02:06 PM
Kajtek1's Avatar
Quoted: 1046 Post(s)
How it works should be a mystery, but you will find few pictorials. Most of blockades works on the same principals, so search other models with mechanical keys as well.
The main issue is that while hiring a butcher for tumbler replacement, you will face steering wheel blockade going into PERMANENT mode.
I can only guess this is what you have cut off by now?
Not switching into gears can be messed up linkage or neutral safety switch.
I consider MB blockade top extreme for DIY jobs and since you have butchered job, very likely the only good advise would be take it to a dealer.
Kajtek1 is online now
