battery alternator - 2006 C230 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-25-2013, 12:04 PM Thread Starter
Date registered: Mar 2011
Vehicle: Mercedes Benz C300 Sports 4matic, Year 2011
Quoted: 6 Post(s)
Angry battery alternator - 2006 C230
Last night, while returning from school, my car showed the message in red - "battery alternator. visit workshop". It cranked up but would not run and the rpm was very low. After about 30 mins, the message went off by itself, rpm increased to normal value and I could drive back to home.
Today morning again I had the same problem. This time I had to wait almost 1 hour with the message until it went off by itself and I could drive.
What is more disappointing is that, I drove to the Mercedes Dealership (hartford, CT) and they said they could not find any problem (bcz the message was not there at that time). They said they checked the battery and the battery alternator and did not find any problem. They asked me to call the Mercedes 24h roadside assistance if I had the same problem. Wtf, the dealership cant diagnose the problem and I have been paying so much for the servicing every year?
Anyways, if you had any similar situation and know what is going on, please let me know. I appreciate your suggestions.
Thank you guys
Have a great day
debargha is offline
post #2 of 7 (permalink) Old 01-26-2013, 10:29 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
It is typical for wear out alternator brushes to act for some time before they will go permanently.
Get new voltage regulator or brushes if they are available in your county.
Kajtek1 is online now
post #3 of 7 (permalink) Old 01-27-2013, 10:01 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Thank you guys
Have a great day
Is the car still on its original battery?
flyboyike is offline
post #4 of 7 (permalink) Old 01-27-2013, 02:50 PM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
On some of the older vehicles, the battery can have an effect on alternator function. Did they actually run a battery test? Do you have an OEM battery? What is the date stamped on the negative terminal if it is an original Mercedes battery? Sometimes it is just a battery issue and if the voltage is not stabilized, you may get that BATTERY/ALTERNATOR message. Once it is stabilized, then the message goes away because there is no longer any problem. Did the dealer also run a self-test and alternator charging test with the diag equipment? I recommend that you ask for the print-outs. I highly recommend with any electrical component, use ORIGINAL Mercedes-Benz parts. Regular batteries should last you 4 years. If it is a VRLA battery (which i doubt), same recommendation. Cheers!
OzzyQ80 is offline
post #5 of 7 (permalink) Old 01-27-2013, 02:51 PM
If the battery was verified to be Original equipment and it passed, then you have an intermittent problem with the voltage regulator in the alternator.
OzzyQ80 is offline
post #6 of 7 (permalink) Old 01-28-2013, 08:26 AM Thread Starter
Quoted: 6 Post(s)
Thank you guys for your valuable replies. I will contact the dealership with these questions. Will let you know what happens
debargha is offline
post #7 of 7 (permalink) Old 01-28-2013, 09:00 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 374 Post(s)
I'm not sure about your C230 - but on a W209 CLK you can do some alternator voltage checks at the cluster.
See here: http://www.benzworld.org/forums/w209...r-voltage.html
keyhole is online now
