Boot closing issue (Alignment) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-20-2013, 04:56 AM Thread Starter
Date registered: May 2009
I noticed that when my boot (SL 500 - R230) is closing the margins (left/right) are unequal. Left-rear side and right front side have smallest margins/gaps from left-front and right -rear.
Info: I have recently repaired my boot lock although I do not think this is related as I played around with the lock to see if it makes a difference.
jid1 is offline
post #2 of 3 (permalink) Old 01-20-2013, 08:03 AM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
the boot lock has no influence on how it is closing. I wouldn't worry too much about it, unless those gaps are significant and the boot does not close properly. I have seen many r230s with uneven gaps. you have to keep in mind that your boot not only opens from the back part of the boot, but also from the front part of the boot when you are going convertible. cheers!
OzzyQ80 is offline
post #3 of 3 (permalink) Old 01-21-2013, 09:16 AM Thread Starter
Thanks for the reply.
Only reason why I thought that it could be related to the lock is that when the pump starts to close the boot, you can see it moving to the left. So I thought that if the lock was not correctly aligned, it would have the same effect. Doesnt seem to be related though.
jid1 is offline
