Help: Interior Light/Open Door Issue - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-12-2013, 02:05 PM Thread Starter
Date registered: Aug 2012
Vehicle: 1987 Mercedes Benz 300SDL, 250K miles
So, I went to start up my 1987 300 SDL today and although the glow plug seemed to light up, the car failed to start.
I thought maybe I left the lights on and the battery was dead, but that wasn't the case.
Anyways, after some investigation, I realized that the passenger door light on the driver's side was on, even when the car was off. It's the light below the ashtray/lighter. I checked all my lighting switches and that wasn't the issue.
I took the car in for an oil change two days before, and noticed when I got in the car and put the key in the ignition, I was getting the warning alarm that sounds when the lights are on or when a door is ajar.
I now think they might have messed something up while they were vacuuming out the back seats, and now the car thinks the side door is open, even though it's not, so the light never went out, and it drained the battery.
My question is how can I fix this issue? Can someone tell me where the door ajar sensor is on the passenger doors? Is this something I can fix myself?
It's my main car, so I need it fixed badly so I don't get stranded with a dead battery.
Thanks so much for any help/advice.
Chicago1987SDL is offline
post #2 of 3 (permalink) Old 01-12-2013, 02:56 PM Thread Starter
Follow up
I went and tried to investigate for a bit and found door ajar sensor (pretty easy).
I pushed the botton in and no surprise, the light did not go off. I pulled the button out and disconnected it, thinking if the wires were not connected, it would go off. No such luck.
I even tried switching it out with the sensor from another door and again no luck.
I was hoping I would find that the button just needed to be replaced, but now I'm at a loss again. Anyone have an idea of something else it could be?
Two of my other doors are missing the light and the housing for it completely, I also found. But when I push those buttons, the remaining light goes off, yet my rear exit light still stays on.
I'm thinking of just removing the light for now, and then trying to revisit the issue in the spring (I'm in Chicago and working outside) and just fix all the doors then.
If I did this, does the exit light pop out on its own, or does the door need to be opened up to get it out?
post #3 of 3 (permalink) Old 01-12-2013, 03:41 PM
Date registered: Jun 2011
Quoted: 81 Post(s)
Sorry all I can tell you is luckily the "puddle lights" pop out easily and the wiring is a simple connector that slides off. Good luck with getting it resolved. Also, when you do fix it, the light assemblies are only like $5 from autohausaz, at least they were not long ago.
w126Sam is offline
