Battery charging... the details (R129, CTEK 7002) - Page 2 - Mercedes-Benz Forum
post #11 of 22 (permalink) Old 01-03-2013, 03:42 PM
R129 HTT Founder Member
Pete S's Avatar
Date registered: Sep 2012
Vehicle: 040 1996 SL500, 775U 2008 R350 4Matic
Quoted: 930 Post(s)
The OP asked for some pics so I hope this helps you somehow. The first pic is where the quick connect hangs from its basically coming down between the bumper cover and the metal of the car.
In the second pic you can see the vent next to the battery where I fished the quick connect through. Takes a little bit of fiddling to get it down but well worth it as when not in use I can simply cap and hide the quick connect up into the bumper cover, and when I do need to charge the trunk doesn't have to remain open.
ID:	487806   Click image for larger version
1996 SL500 Photo Collection Updated 01-14-16
Mercedes aren't for people who want to have one, it's for people who can have one.
Pete S is offline
post #12 of 22 (permalink) Old 01-03-2013, 06:21 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1340 Post(s)
When you are making permanent connection, there is high risk of forgetting it and drive off without disconnecting.
2 common ways to avoid sometimes danger problems
1. make a reinforcement plugs that will disconnect in the direction of driving away
2. make a red flag with a note that you put on the steering wheel when the plug is in. When you disconnect the plug, it will go to the location of the plug or next to it.
Kajtek1 is online now
post #13 of 22 (permalink) Old 01-03-2013, 06:31 PM
Date registered: Jan 2012
Vehicle: V230 VIN No. VSA638234-23-071305, E230 VIN NO. WDB2110522B345601
Quoted: 7 Post(s)
Just a practical question:
If the cables of the charger are permanently connected to the battery's +/- terminals, will there be constant discharge of battery power when the charger is not connected?
henryhsu is offline
post #14 of 22 (permalink) Old 01-03-2013, 06:42 PM
Quoted: 7 Post(s)
Originally Posted by darrelstickler View Post
Have the usual situation with a classic ('92 300SL) that doesn't get driven much. Bought a CTEK 7002, which seems to work nicely.
The 100 Ah Made-in-Spain battery is in the right side of the trunk. I hooked up the "permanent" fittings to the + and - terminals with the idea of plugging in the charger and leaving it, maybe for months at a time.
1. With this type of charger (which isn't overdriving voltage and boiling the battery), do I need to loosen the battery caps? I've always done this (40+ years) whenever hooking up any charger, even though my brain says batteries must be able to vent themselves.
2. To confirm, the reason why one always hooks up the negative "jumper" away from the battery is to avoid sparks. Since the charger is unplugged (and on the garage floor) when 0I'm hooking up the charger connector to the permanently installed battery jumpers, this is no problem, right?
3. Do I need to have the trunk propped open for ventilation when the charger is just doing normal maintenance charging? Again, it seems like Mercedes didn't worry about this since the trunk is closed when the car is being driven and charged, but there's probably more ventilation in the trunk in motion than just sitting in the garage.
Thanks for any reasoned advice. Happy New Year.
Amazon.com: CTEK Multi US 7002 12V Battery Charger: Automotive
Since Peter S. has provided you with a equivalent solution, I will not offer any clues to
(1) & (2) but if I were you, I will not leave a battery charger sitting in the closed car boot for a month since the battery charger is plugged into a household electrical outlet of either 110 or 220V. One can not be more careful.....
henryhsu is offline
post #15 of 22 (permalink) Old 01-03-2013, 07:29 PM
Pete S's Avatar
Quoted: 930 Post(s)
No. Since it is just that a cable, and not hooked up to anything, it won't draw anything from the battery.
Pete S is offline
post #16 of 22 (permalink) Old 01-03-2013, 08:35 PM
Quoted: 7 Post(s)
Noted. So you will only connect the charge cables to the +/- terminals when you intend the charge the battery! Do you wrap the connector located at the rear bumper to avoid road dirt?
henryhsu is offline
post #17 of 22 (permalink) Old 01-03-2013, 08:39 PM
Pete S's Avatar
Quoted: 930 Post(s)
Correct I only plug it into the battery tender when I know I won't be driving it for a few days/weeks. If you look closely at the first pic you will actually see the cap that covers the exposed connectors. No way would I wedge it between the bumper cover and body if everything weren't covered, otherwise i could create some nasty a&$ shorts!
Pete S is offline
post #18 of 22 (permalink) Old 01-03-2013, 09:08 PM
Quoted: 7 Post(s)
I am not trying to argue the point but from the picture, I can see two cables coming our of the vent and the thinner cable is connected below the actual battery cable i.e. these two cables are connected permanently to your +/- terminals. Now it depends on how good is the insulation of the connector to prevent minimal power leakage.....
I am not an expert but I would connect and disconnect after each battery charging.
henryhsu is offline
post #19 of 22 (permalink) Old 01-04-2013, 01:25 PM
Kajtek1's Avatar
Getting paranoid, aren't we? Plugs with covers sticking outside are pretty common in industrial applications and unless they are exposed to salty spray they don't create problems.
On the other hand I had several of MB models parked armed for up to 5 weeks with nothing done to charge them and they all started on their own power. Sure I was not dealing with subfreezing temperatures, but that gives you idea how good those cars are.
post #20 of 22 (permalink) Old 01-04-2013, 04:17 PM
Quoted: 7 Post(s)
Actually I was referring to the cables permanently attached to the battery's +/- terminals and asking the question whether there is minor leakage to somewhere? I had experience that the battery power could be deminished slowly and may be that is the reason for the need to recharge?
I would only connect the cable to the battery when I intend to recharge the battery.
henryhsu is offline
