Brakes and rotors - is brand important? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 12-18-2012, 08:41 AM Thread Starter
Date registered: Dec 2012
Vehicle: 2006 S500 4matic
Quoted: 4 Post(s)
Hey Guys,
I am glad that I found this forum - so much useful information!
I am about to replace front brakes and rotors. My car brakes great, no vibration or any other problems but my mechanic told me 10000 miles ago that my rotors are 5 mm wore out.
I got to amazon.com and found hundreds of options priced from $20 to 200. I am confused. Are rotors really so much different? Does cross drilling make them better? Are more expensive brake better?
Any finally - do I need semi-metalic or ceramic brakes?
Thank you
Barmaley is offline
post #2 of 12 (permalink) Old 12-18-2012, 02:01 PM
RedMercedesGuy's Avatar
Date registered: Feb 2012
Vehicle: 2014 Mercedes-Benz C300, 2006 Lexus IS250 AWD, 2006 Land Rover LR3 SE, 2000 Ranger R83
I bought my cross drilled rotors from Brakeworld (I think). Cross drilling helps them to cool a little quicker but unless you do really agressive braking I don't know whether it makes that much difference. I just liked the cross drilled better and was willing to spend a little bit more.
As far as pads go, I went with the Akebono Euro Ceramic pads. They do a good job of stopping me and there is NO dust.
RedMercedesGuy is offline
post #3 of 12 (permalink) Old 12-18-2012, 06:25 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1340 Post(s)
Cross-drilling helps a lot when you have to make panic stop from 150 mph.
Rotors are mild steel. Mild steel is like clay. No matter from China or Germany - clay is clay.
It is pads that makes the big difference. If you are all for performance - go for OEM but they leave lot of dust.
Lot of members switched to Akebono pads that leave almost no dust, while difference in performance is not noticeable.
Kajtek1 is offline
post #4 of 12 (permalink) Old 12-19-2012, 06:27 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Originally Posted by Barmaley View Post
Hey Guys,
I got to amazon.com and found hundreds of options priced from $20 to 200. I am confused. Are rotors really so much different? Does cross drilling make them better? Are they more expensive brake better?
Thank you
That's like asking Aibolit whether he preferred a cheaper parachute or a more expensive one when he fell on Barmaley.
flyboyike is offline
post #5 of 12 (permalink) Old 12-19-2012, 04:00 PM
Vehicle: 2006 CLS 500
I bought cheap rotors from China for my wife's Audi A6 and after about 5 months of 80% stop-n-go traffic they started to shudder. After it got worse I decided not to keep them on the car.
They were replaced with OEM Audi parts about a year ago and no problem yet.
My opinion is that it's really hard to tell the quality of something based just on price. Over-spending for a part certainly doesn't guarantee checkered flags and champagne.
Having said that, in general, my experience with cheap parts, like cheap tools, is that they end up causing more aggravation than they are worth.
For MB, I try to find OEM manufacturers so that at least there are some standards involved.
Schaeffer
Schaeffer is offline
post #6 of 12 (permalink) Old 12-19-2012, 04:16 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
As a basic rule, I'd avoid amazon (as well as flea-bay) for parts unless you know exactly what you're doing. And based on your post, you don't (please don't take that the wrong way, but really, if you knew, you wouldn't ask, true?)
Best to stick with a good brand from a known vendor.
If you like things simple, buy the Zimmerman Z-coat rotors. The coating obviates the need for any particular bed-in procedure (just don't drive the brakes hard for a few hundred miles) and Zimmerman is an OE supplier for many European car makers.
If you don't mind brake dust, stick with OEM for the pads. They're usually cheaper and are designed to work great wet or dry, hot or cold. If you hate brake dust, Akebono are a popular choice, though I personally prefer Axxis Deluxe Plus.
Good luck.
Check Codes is offline
post #7 of 12 (permalink) Old 12-19-2012, 04:23 PM
Date registered: Feb 2011
Vehicle: 2000 C230 Kompressor Special Edition
Quoted: 15 Post(s)
Balo rotors and Akebono Euro pads, and you will be happy.
Balo is made in Germany and Akebono is made in USA.
Mercedes-Benz - Engineered like no other car in the world.
bachusattackus is offline
post #8 of 12 (permalink) Old 12-24-2012, 08:51 PM Thread Starter
Quoted: 4 Post(s)
Thank you for advice! I have bought the parts and ready to install them. I did change brakes several times in Cadillac DTS. Are there something notably different in the brake design on MB brakes on S500 4matic? Do I need any special tools?
Thank you.
Barmaley is offline
post #9 of 12 (permalink) Old 12-24-2012, 10:16 PM
Date registered: Oct 2012
Vehicle: CLK500, BMW X3
zimmerman rotors and OEM pads have always worked great
fivepointnine is offline
post #10 of 12 (permalink) Old 01-03-2013, 08:37 PM
Vehicle: 368 W211 M273
What I plan on doing in the next 10,000 miles is the exact same as my 2007 Acura TL-S, source OEM pad and rotors, have the rotors cyrogenically treated and installed at the dealer.
What alot of people don't understand is, cryogenically treating the rotors will help extend the life of the rotors tremendously and eliminate the heat spots in the rotors. And, it is cheap to have them cryoed.
J Dubya is offline
