Horn not working ? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-28-2012, 04:00 PM Thread Starter
Date registered: Feb 2012
Question Horn not working ?
Hello fellow M.B. owners....my 2007 E350 horn does not work (guess how I found out!). I looked at the fuse box and looked at the fuse chart that shows what each fuse controls however there is no fuse listed for the horn...any suggestions short of bring it to the dealer ? Thanks in advance !
cameyer85 is offline
post #2 of 2 (permalink) Old 11-28-2012, 06:29 PM
Date registered: Nov 2012
You should check presence of voltage in the horn and make sure it is firmly mounted. If presence of dirt and dust remove both horn frames and clean it. If voltage is working good at fuse not in the horn the problem might be the wiring or switch.
If a horn stop working then the other horn here comes the issue. Assemblies of both horns usually work at the same time. If it fails, both horns have a problem.
I hope you get an idea from my suggestion.
BlueBlackBenz is offline
