code p0410 secondary air pump malfunction - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-23-2012, 01:34 PM Thread Starter
Date registered: Nov 2012
I have a 2007 E 350 and my check engine light came on with the
P0410 code secondary air pump malfunction. I checked with the dealer and they are asking between $1,000 and $1,200 to replace the pump.
Any suggestions?
stabajaba is offline
post #2 of 3 (permalink) Old 11-23-2012, 03:02 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
The part lists for $700. Not sure how they are getting up to 4.5 hours labor to change it.
You may want to ask them what they are charging for just the labor. has the OEM MB packaged part for $499.
It is a straightforward job. Should not be more than 2 hours labor at the most. will check MB's WIS later to confirm labor, but on the E500 it took me 45 minutes including
the code checking and clearing.
This is an emissions item. Are you in the US? If the car is less than 80,000 miles they
should be replacing it at no charge. At least that is the emissions law in my state.
Noodles is offline
post #3 of 3 (permalink) Old 11-23-2012, 05:24 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
make sure you also change the relay that controls the pump, the most common problem is with the relay sticking and burning up the pump
saleen1276 is offline
