rear wheels, streight vertical or little bit inward? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-19-2012, 10:59 PM Thread Starter
Date registered: Oct 2012
Vehicle: 1998 C43
Hey guys. I have 1998 c43. Should my rear wheels be streight vertical or upper wheel should be a little bit inward?
How does your look like?
eduardbro is offline
post #2 of 4 (permalink) Old 11-20-2012, 01:22 AM
Date registered: Jul 2005
Quoted: 1088 Post(s)
Are you referring to the camber and whether it is positive or negative?
Which direction are yours going in.
For best tire wear straight is ideal. For best traction under full power a little negative camber is better. The would be the top of the wheel and tire being angled in a tiny amount at the top of the wheel arch.
Noodles is offline
post #3 of 4 (permalink) Old 11-25-2012, 07:12 PM Thread Starter
Vehicle: 1998 C43
Mine are little bit negative - top of the wheel are going inward a bit
post #4 of 4 (permalink) Old 11-25-2012, 10:13 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
I never put a gauge on the wheels, but even I had alignment check twice on my W210, the tire wear out on inner sides about 2 mm more than on the other sides.
I got 53k miles on 50k rated tires, so not much to complain, but seems MB design their cars with better traction in mind - wearing the tire unevenly as a side effect.
As always in the life - can't have them both ways.
Kajtek1 is offline
