2005 S430 - Left Headlight Problems - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-13-2012, 08:38 AM Thread Starter
Date registered: Nov 2012
Vehicle: 2005 S430
I have seen plenty of strings concerning headlight issues but none of them have solved my problem yet. I sometimes get low beam alert but the light still works after turning it off and on. Now am continuously getting a L Turn Signal out message. I pulled the bulb out of the passenger side and put in into the drivers (and vice versa) and it still did not work. The passenger side turn signal still worked with the other bulb in it. I am now getting a L side marker signal along with the turn signal warning. The LED's on the mirror still work but that is the only indicator I have that is visible on a left hand turn. Is there a fuse I should be checking? A ground? Wiring harness? I am new to this forum however I have followed the q&a and am quite impressed with support. Any help/suggestions will be greatly appreciated.
nolarooster is offline
post #2 of 2 (permalink) Old 01-24-2013, 11:53 AM Thread Starter
Vehicle: 2005 S430
Well, I took it to the dealership. You were correct. Apparently I had plenty of bulbs out and the codes needed to be reset as well.
