New member, 1997 S 500 starting problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-12-2012, 08:36 PM Thread Starter
Date registered: Nov 2012
Vehicle: 1997 S 500
Hello, my name is Greg Heinrichs of NY,NY and I recently came into possession of a 1997 S500 that had a bad fuel pump. I replaced the pump, fuel filter and battery, checked plugs for fouling, have spark and fuel at fuel rail in engine compartment and the car will not start. It sounds like it wants to kick over sometimes but won't. What can I troubleshoot next to determine the problem? Should I replace the crankshaft position sensor--I can get one for about $33.00. Any guidance is helpful. The car was running 3 weeks ago but stalled and the fuel pump was bad - it would not go on with power to it while cranking--new pump comes on.
1997s500 is offline
post #2 of 4 (permalink) Old 11-14-2012, 11:24 PM
eric242340's Avatar
Quoted: 311 Post(s)
Welcome to Benzworld, it is not the CPS because you have spark and fuel, if a faulty CPS then no spark and no fuel.
ERIC.
eric242340 is online now
post #3 of 4 (permalink) Old 11-15-2012, 01:47 PM Thread Starter
Vehicle: 1997 S 500
Thanks, I thought so and you and others have confirmed it. I have replaced the old out of gap spark plugs and the CAM position sensor--it came up on the OBD II fault code reader. It sounds like it wants to start at times but still does not. I am going to wipe off the maf, put some techron in the tank and maybe spray some starter fluid in the throttle body while cranking to see if it will kick over. I will also continue to check for spark and fuel at the rail and then possibly test the injectors. Any other suggestions are greatly appreciated.
1997s500 is offline
post #4 of 4 (permalink) Old 11-15-2012, 05:22 PM
eric242340's Avatar
Quoted: 311 Post(s)
You need 3 main items to fire, fuel/spark and compression. You have fuel and spark.
ERIC.
