1995 SL 500 power loss smells like rotten eggs - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-07-2012, 04:03 AM Thread Starter
bmwmikec's Avatar
Date registered: Oct 2012
i am new here.........aloha...yes i am from Hilo Hawaii Usa....
Have a 1995 SL 500 loss power the other day.....after satrting up warm after parker for 10 minutes, rough idle ..check engine light on. Drive off the lot and it hasw no power at all...barely goes to 4000 rpm with pedal to forr...feels like 4 cylinder; however, no misfire.
next day changed fue filter, not too bad, bout had it off......the one that fits is the one with nipples on end not fitting.....my partys guy said it was for a 1997 model S L 500....fuel sample looks clean, fesh, no water
check the rotors, distributor cap and plugs...all good, plugs like new bosch...look a little lean. Non fouled
Restart same problem...no power test drive no power, again a bit of a rotten egg smell.. HELP ?
thinking about clogged catalyst ? or maybe how to clear the codes ?
in park from idle rev it up and sounds like a bit of swooshing out the exhaust like clogged catalyst.....car has 74,215 miles on it...very pristine car......air filters super clean....
Also when i bought the car 5b months ago the radio was off and i head to recode it toi work leading me to believe that either the battery was dead , diconnect for a time or replced.......could this be a problem starter ?
All help cordially invited
No good mercedes or independent shop within 100 miles ....HELP
My best guess was to disconnect the twin catalytic converters up front and run it open ....however, a friend said that mercedes benz have problems with codes some time when battery disconnected or changed and neeed to be cleared......
bottom line is i need help.... i do not have a scanner,,, my friend has a snap on scanner and we are not sure if it will give the coeds and or clear them
First things first...Whats my next step please ?
bmwmikec is offline
post #2 of 8 (permalink) Old 10-07-2012, 04:16 AM
eric242340's Avatar
Quoted: 309 Post(s)
Does the engine rev normally when the car is in park?
ERIC.
eric242340 is offline
post #3 of 8 (permalink) Old 10-07-2012, 06:50 AM Thread Starter
bmwmikec's Avatar
1995 mercedes benz SL 500 power loss / check engine light
Revs up ok in park.....maybe a bit off
just doesn't have that power sound out the exhaust
has a swooshing sound shhhhhhhhhhhhuuuuuuuuuuu
bmwmikec is offline
post #4 of 8 (permalink) Old 10-07-2012, 06:57 AM
eric242340's Avatar
Quoted: 309 Post(s)
There are two distinct possibles here without reading the codes that I can think of and CATS are def one possible, loosening the pipes and testing is a good idea. Also a blocked cat will get very hot and may be burning sulfur which would create the bad egg smell.
The other is the MAF sensor as you said the plugs seemed to look like a lean mixture. But for the MAF test equipment is needed to verify this.
ERIC.
post #5 of 8 (permalink) Old 10-07-2012, 08:21 AM Thread Starter
bmwmikec's Avatar
yes.........we are thinking along the same lines......
Is there a cheap easy way to get the codes...and then clear them ?
I would really like to get the codes and clear them
Especially before taking off the exhaust upstream of the cats...
bmwmikec is offline
post #6 of 8 (permalink) Old 10-07-2012, 08:25 AM
eric242340's Avatar
Quoted: 309 Post(s)
I cannot help with test equipment, but there is no such beast as cheap test equipment.
You do not need to take the exhaust off, simply loosen the joints upstream of the cats and test it like that, a little noisy yes but it will prove or disprove this. Loosening the connections will allow any back pressure to escape.
ERIC.
post #7 of 8 (permalink) Old 10-07-2012, 09:24 AM Thread Starter
bmwmikec's Avatar
1995 SL500 POWER LOSS
I WILL TAKE THE PIPES LOOSE TODAY AND SEE HOW THAT GOES.....
ANYBODY ELSE GOT A WAY TO GET THE CODES AND CLEAR THE ?
EVEN IF IT IS THE MAF SENSOR ...AND I REPLACE IT...
I WILL NEED TO CLEAR THOSE CODES. i AM SURE OF THAT
i SEEN SOME GUYS MADE AN INEXPENSIVE LED DISPLAY WITH SOME CLIPS AND WIRES THEY CLAIM THEY MADE FROM STUFF AT RADIO SHACK.......ANYBODY GOT ONE THEY WANNA SELL ?
I WOULD LOVE TO HAVE ONE......BUT NO TIME TO DO THE SOLDERING ETC....
LET ME KNOW OR ELSE ADVICE ME OF A COMMON SCAN TOOL A LOCAL TECH MIGHT HAVE HERE THAT CAN GET AND CLEAR MY CODES....
THANKS
bmwmikec is offline
post #8 of 8 (permalink) Old 10-07-2012, 09:31 AM
eric242340's Avatar
Quoted: 309 Post(s)
THANKS
Ask fellow owners, as they may know;
R129 SL Class - Benzworld.org - Mercedes-Benz Discussion Forum
ERIC.
