Any reason NOT to replace brake pads with ceramic? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-29-2012, 12:58 PM Thread Starter
Date registered: Oct 2006
I believe I need to replace the rear pads on my '85 300TD. Seems like most all of the parts houses here only stock organic compound pads, but can order in ceramic. Any reason not to spend a little extra $$ to get ceramic?
Also- I only found one place that could order semi-metallic, but they are about the same $$ as the ceramic.
Thanks in advance for replies.
turboJOB is offline
post #2 of 6 (permalink) Old 09-29-2012, 03:49 PM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
Do a search on "brake pads" or "brake dust" and you will see a lot of discussions on this subject.
I wanted to replace my OE pads because of the brake dusts. I ended up with OE pads eventually.
mis3 is offline
post #3 of 6 (permalink) Old 09-29-2012, 09:12 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1342 Post(s)
Just ceramic brake pads doesn't mean much and can be danger.
Do Akebono ceramic brake pads and you will love it.
Amazon has good prices on them.
Kajtek1 is offline
post #4 of 6 (permalink) Old 09-30-2012, 08:40 AM
galaxys's Avatar
Date registered: Nov 2008
Vehicle: 2011 SLK300 Plutonium Silver (2002 SLK230 Sold)
I switched to ceramic awhile ago and have never looked back!
galaxys is offline
post #5 of 6 (permalink) Old 11-06-2012, 08:02 AM
Date registered: Mar 2012
Vehicle: R500
I changed front with akebono still have semi-metallic on rear, the cleanliness is night and day. As for performance, I think they are very good if not better.
Sent from my iPhone using Autoguide.com Free App
wldkatz is offline
post #6 of 6 (permalink) Old 11-07-2012, 06:57 AM
Musikmann's Avatar
Quoted: 6 Post(s)
As mentioned this forum is littered with alternative brake pad discussions. But to answer your question, the only possible reason not to buy them (from what I've read) is they are harder on the rotors. But on the other hand, rotors are not very expensive.
Musikmann is offline
