CLK 240 yet another transmission problems - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-15-2012, 01:01 PM Thread Starter
Date registered: Sep 2012
Vehicle: CLK 240 (2003)
Hello all,
after car jerking when placed into D or R and being stuck in one gear, as advised I checked the TCU for oil and replaced the conductor plate, socket, filter and ATF, all Mercedes parts. No foreign material was found, oil did not smell burnt but just like the new oil, no water or coolant in oil either. Checked oil level and it's just on max whilst 80 degrees. Reset P2502 and P2503 codes on TCU and was unable to reset code P206D on ECU. All codes came back and now have following issues; drives normally no jerking, shifting gears smoothly, then gets stuck in one gear and makes whining noise, the faster I go the louder the noise, then goes away the next day. Also when engage into D, it drives, but shortly after it doesn't drive, when try to re-engage nothing happens, as normally you can feel when the D or R engage because of hardly noticeable jerk. When turn off and on the engine, it re-engages ok, drives, shifts, and no whining noise. Basically everyday I don't know whether it will drive, or get stuck, or won't engage at all.
Apart from checking solenoids and springs under the conductor plate I have no other ideas but to ask the professionals before I remove the sunk yet again. Could it be the well known torque converter and/or pump?
95,000km on the clock.
DRONYA is offline
post #2 of 5 (permalink) Old 09-16-2012, 02:15 AM
eric242340's Avatar
Quoted: 307 Post(s)
Torque converter not locking up? This may explain the whine noise, but I am guessing here.
ERIC.
eric242340 is offline
post #3 of 5 (permalink) Old 09-20-2012, 02:48 AM
Vehicle: Mercedes W210 E240
Send a message via Yahoo to w210e63 Send a message via Skype™ to w210e63
Hi,
Have you solved it. I got the almost same problem.
Pls keep update!
Thanks
Mark
w210e63 is offline
post #4 of 5 (permalink) Old 09-20-2012, 03:38 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 387 Post(s)
For the best chance of a response from someone with a similar experience, I wish that this thread had been posted on the W209 forum - that is where most owners hang out. Generally, transmissions in the 722.6 family seem very reliable.
New Members is Eric's domain...
keyhole is online now
post #5 of 5 (permalink) Old 09-20-2012, 05:52 AM
eric242340's Avatar
Quoted: 307 Post(s)
Correct my friend, the best forum for the OP is;
W209 CLK Class - Benzworld.org - Mercedes-Benz Discussion Forum
ERIC.
