Help bleeding air out of brakes please? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-28-2012, 06:51 PM Thread Starter
Date registered: Jul 2010
Hello BenzWorlders,
I recently bought and assembled a pressure bleeder from MercedesSource. Today I pressure bled the brakes on my 99 w202 c280. Everything there seems to be fine, better than before in fact.
However, I used the same procedure for my 89 w124 300e and have a problem.
The brake pedal is really soft for more than half its initial travel and at the deep end of the pedal travel, there isn't as much braking as there used to be.
I suspect there is air in the system. How can I bleed the air out? Do I need more brake fluid? What do you recommend?
1989w124 is offline
post #2 of 2 (permalink) Old 06-29-2012, 03:49 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Keep bleeding until you see no more bubbles.
flyboyike is offline
