W163 aux electric pump shorted & melted the wire connector... need to locate a connec - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-23-2012, 07:08 PM Thread Starter
Date registered: Nov 2007
Vehicle: 99 ML 320
My 99 ml320 aux electric water pump shorted out and melted the connector.
there is no part number on the connector...does this mean that i woulds need to get a new wire harness just to replace this one connector...can i get the connector any where else..i can splice wires to make it easy..i rather not run a new wire harness or have to buy one....and ideas..before i just hard wired it...
please advise
thanks
shantiyoga is offline
post #2 of 9 (permalink) Old 06-24-2012, 03:04 AM
Kajtek1's Avatar
Quoted: 1168 Post(s)
Is that inside the tank connector? I had one of those on ML55. Even the truck was long time after warranty period - MBUSA after some nagging paid for new fuel pump. This is the only way MB sells it.
Kajtek1 is offline
post #3 of 9 (permalink) Old 06-24-2012, 09:17 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Kajtek, read his question again. Carefully. Once you've done that, tell how you possibly got anything having anything to do with fuel out of it. Must be Polish logic again.
To the OP, which side of the connector did it melt? Can you post a pic?
flyboyike is offline
post #4 of 9 (permalink) Old 06-24-2012, 03:21 PM
Kajtek1's Avatar
You are right. I speed-read concluding this is related to the problem I did have.
To avoid confusion, ML is having mechanical water pump that has no electric connector on it. I guess OP talks about coolant recirculating pump. Those to my knowledge come as single piece and not come cheap. Some members were able to make new brushes for them as that is what usually go.
Electric connector should be easier to manufacture than bushes?
Kajtek1 is offline
post #5 of 9 (permalink) Old 06-24-2012, 07:19 PM Thread Starter
Vehicle: 99 ML 320
I just trying to locate the connector for the aux recirculation water pump....
I can rig, something.... But I rather locate a new connector.....
Sent from my Autoguide iPhone app
post #6 of 9 (permalink) Old 06-24-2012, 09:23 PM Thread Starter
Vehicle: 99 ML 320
Actually both the bottom of the pump which the connector plugs in as well part of the connector... Post a pic tomorrow... Thx
post #7 of 9 (permalink) Old 06-24-2012, 09:24 PM Thread Starter
Vehicle: 99 ML 320
Both melted... I got a new pump from auto haus..... Locating a new connector seems more difficult with out buying a whole wire harness ....
post #8 of 9 (permalink) Old 06-25-2012, 11:12 AM
flyboyike's Avatar
Quoted: 68 Post(s)
I would suggest finding a connector at a junkyard and then splicing it in. Better than hard-wiring it.
post #9 of 9 (permalink) Old 06-26-2012, 04:22 AM Thread Starter
Vehicle: 99 ML 320
Amazingly dealer is hooking me up with the pigtail assy ... For under $30..
Thanks all
