95 E320 Wagon ASR Problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-19-2012, 08:31 AM Thread Starter
Date registered: Jun 2012
Post 95 E320 Wagon ASR Problem
I have a 95 e 320 station wagon with 102,000 miles that is in beautiful condition but it is in Limp Mode for 2 years this August.I have replaced the engine wiring harness, throttle actuator, break light switch, ASR dash switch, gas pedal switch, transmission reverse light switch,air mass censor was checked and okay, e gas module was checked and okay,voltage over protection relay replaced, new battery, new break pad sensors, etc. I am at my wits end and desperately need help to find a solution to this problem. The car starts and idols. The lights on the dash upon starting go on as they should, and the car will idol all day. The minute I hit the gas pedal the ASR light comes on and the ABS light flickers and the car will not go over 30 miles an hour or shift. Please help if you can and know I appreciate it tremendously. Thank you!
Mr.TBird is offline
post #2 of 2 (permalink) Old 06-19-2012, 07:59 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld, what are the fault codes? Just throwing parts at it will not fix it as you have found out, you must start with the fault codes.
eric242340 is online now
