A/C problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-04-2012, 07:21 PM Thread Starter
Date registered: Jun 2012
Vehicle: 2004 C230 Kompressor
A/C problem
I have a 2004 c230 Kompressor and my a/c is acting up. When I first get in the car in the morning the a/c works great, but as the day wears on, 2 things happen: 1. The temp gets warmer, still cool but not as cold as when I first get in. 2. The amount of air coming out the vents gets weaker and weaker. I literally have the fan on full/max and there is barely a noticable amount of air coming out of the vents. This starts in the morning and lasts all day. The next morning starts all over again, blowing cold air strongly then slowly decreasing to cool air with minimal air flow.
docktoro1 is offline
post #2 of 4 (permalink) Old 06-04-2012, 11:37 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Sounds like you are low on refrigerant and the evaporator is gradually freezing (or the evaporator gets frozen for some other reason).
You might get better guidance from the W203 forum:
W203 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
Welcome to the forum.
Diesel Benz is offline
post #3 of 4 (permalink) Old 06-05-2012, 01:52 PM
If the refrigerant was low, how would the evaporator get cold enough to freeze? Sound like you have a stepper motor problem. Do you hear any plastic clicking noises in the dash when you turn on the car?
BenzTek Motorsports is offline
post #4 of 4 (permalink) Old 06-05-2012, 02:14 PM Thread Starter
No noises when I turn the car on! Can I check the freon level and how?
    Vito 108CDI Electrical problem and Instrument Cluster problem DJDUNKY V-Class 2 03-30-2010 02:05 AM
    Electric side mirror problem / Seat Electronic problem taime R170 SLK-Class 8 05-24-2007 06:03 AM
    1994 S600 coupe "Vacuum assist pump problem and now a starting problem Bigpauly52 W140 S-Class 18 09-26-2004 01:36 AM
    Interesting new problem, or is it a problem? My car's water broke yesterday Jason Y R170 SLK-Class 8 06-13-2001 07:54 PM
    Update on my cold start studdering problem - problem fixed? Douglas-Indianapolis R170 SLK-Class 4 04-25-2001 05:28 AM
