Glow plug relay - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-03-2012, 09:18 AM Thread Starter
Date registered: Oct 2011
Vehicle: 1997 E300D
Glow plug relay
Hope you guy can help me , I have two 97 E300d and both some times wont turn on the glow plug light. I turn the key off and on a few time and some time spin the eng before the light will come on and the cars start fine cold or hot. I cleaned the small two wire that plug in to the relay but that didn't help. Could someone tell me where the two small wire go to and what make the circuit and is it any way to ground or run a hot wire to the relay if I cant get them to crank in a emergency . The relay and key sw was changed on one of them and it was a can of starting fluid in it so I think it been a problem for a while. Thank for any help or a wiring diagram
Eightballl is offline
Glow plug(s) or glow plug relay...? kavakava W123 E,CE,D,CD,TD,TE Class 16 03-04-2010 07:45 PM
Late Glow glow plug relay smallfence W123 E,CE,D,CD,TD,TE Class 16 10-21-2009 06:33 PM
DIY Glow plug relay and Glow plugs 240Dbio W123 E,CE,D,CD,TD,TE Class 17 06-18-2009 03:38 PM
Glow plug problems, no power to the glow plug relay kbbenz78 W123 E,CE,D,CD,TD,TE Class 8 11-15-2006 08:45 PM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 04:58 PM
