1992 400E Long delay going into reverse - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-03-2012, 07:17 AM Thread Starter
Date registered: May 2012
I have a 1992 400 E that takes 15 seconds to go into reverse gear and sometimes longer. ATF fluid is checked and to the full line.
Any suggestions ?
Captd is offline
post #2 of 2 (permalink) Old 06-03-2012, 06:31 PM
BenzSid124's Avatar
Date registered: Jun 2012
Vehicle: 1994 E320, 1990 300CE Coupe, 1971 280S
Common w124 problem...reverse gear clutch pack is worn out so it takes longer for it to fill with trans fluid to engage reverse. Transmission needs to be rebuilt. It's the first sign of a worn transmission. Reverse gear will always go out first. Seen a lot done at my dealer and I've had to do mine personally for that reason. Once its done though the car will run like new.
-Sid
BenzSid124 is offline
    Transmission Delay In Reverse steinerhayes W124 E,CE,D,TD Class 6 08-25-2011 07:50 AM
    5 second delay in reverse fixed. mbnz230 W140 S-Class 12 07-10-2010 06:26 PM
    Delay in reverse? P10 W140 S-Class 15 06-28-2007 09:04 AM
    Delay going into reverse corgi R129 SL-Class 7 04-18-2007 07:38 PM
    long delay to switch to Reverse graymarket500SEL W126 S,SE,SEC,SEL,SD,SDL Class 8 01-14-2003 03:58 AM
