Replacing disk brake pads on 98 E320 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-02-2012, 06:05 AM Thread Starter
Date registered: Jun 2012
I typically keep my MB for years and do most of my own repairs. However, I can't seemt to remove the caliper pins from the unit to remove the pads. Does anyone know the correct tool to remove the pins?
billcain is offline
post #2 of 3 (permalink) Old 06-02-2012, 07:09 AM
eric242340's Avatar
Quoted: 312 Post(s)
Welcome to Benzworld
http://www.benzworld.org/forums/atta...-diy-brake.pdf
http://www.benzworld.org/forums/3573121-post1.html
ERIC.
eric242340 is online now
post #3 of 3 (permalink) Old 06-02-2012, 11:19 AM
Date registered: May 2004
Vehicle: 1985 190E2.6(junked), 1995c220, 2000CLK430(totaled), 2001C240, 2009 CLS
That's a fairly nice DIY, But! I personally would not compress the piston as suggested in the DIY, reason is that you may flush all the junk in the caliper into the ABS (possibly) . Rather than that, first open bleeder, then compress piston, when completely compressed,close bleeder, then you can follow the DIY and not risk screwing up a expensive ABS computer, and as long as, your going thru all of that , consider flushing system(if you haven't already) I use Ate SL.6 ( Dot 4 class6), don't use silicone on ABS . If you screw up the pins, rockauto has them . Good luck
benzover is offline
Replacing brake rotors and pads on a 95 E320 W124 - first time DIY observations 71Rcode W124 E,CE,D,TD Class 14 02-11-2015 11:35 AM
Timing for replacing brake pads velospoke W124 E,CE,D,TD Class 6 12-28-2010 12:34 PM
replacing brake pads on an 03 e320 dakota450 The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 12-12-2009 06:30 AM
replacing brake pads!!!!!!!! amgstyle R170 SLK-Class 4 08-21-2006 01:24 PM
replacing brake pads TOMMYMCA79 W124 E,CE,D,TD Class 3 07-03-2006 02:49 PM
