Pink Headlight - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-01-2012, 07:55 PM Thread Starter
Date registered: Jun 2012
Pink Headlight
I have an 08 CLS. The driver's side headlight is dim. It is pink in color. Is it the bulb or the ballist? How do I remove the headlight unit?
Paladin62 is offline
post #2 of 5 (permalink) Old 06-03-2012, 09:36 AM
Date registered: Jan 2012
Vehicle: 2001 430T 4Matic, 1999 735iA
Quoted: 15 Post(s)
if the light is pink,the bulb is "poisoned" -> the xenon bulb has got trace amounts of oxygen in it. I´d start replacing the bulb. (Do both sides, costs about 60€ for philips 85122 bulbs..)
MeMySelfundIch is offline
post #3 of 5 (permalink) Old 06-04-2012, 05:15 PM Thread Starter
Turns out I have the Bi-Xeon lights. The manual says not to attempt replacement at home... I got the cover off, the ballist out but could not remove the bulb. There got to be a trick to it. What is the trick?
post #4 of 5 (permalink) Old 06-05-2012, 12:42 AM
Quoted: 15 Post(s)
not sure, but why don't you go looking in your Vehicles own section? There is bound to be a how to there!
post #5 of 5 (permalink) Old 06-05-2012, 12:36 PM
Did you just have the xenon bulb replaced? When you install a new bulb, you have to let the new bulb "burn in". New bulbs are usually a pinkish color until they "burn in". If its not a new bulb than you might just have a bad bulb. Dont touch it if you dont know what your doing. Factory bulbs are very expensive ($150-$200) or you can always get the cheap ones off ebay and hope they last.
BenzTek Motorsports is offline
    Pink Vs. Pink Floyd ThrillKill Off-Topic 29 08-17-2011 11:34 PM
    headlight turning pink? mike_balt W164 M-Class 3 04-15-2011 06:01 AM
    Red...or Pink? strife2 R/C107 SL/SLC Class 7 01-13-2011 04:28 PM
    Pink Headlight 61loub W163 M-Class 11 08-09-2009 03:27 AM
    Pink deathrattle Off-Topic 6 01-04-2007 02:19 AM
