S-Class W220 Battery Drain (TV?) - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-31-2012, 03:49 AM Thread Starter
Date registered: May 2012
I have a 2001 S Class (W220) and recently the battery keeps dying.
I think I have narrowed it down to the centre console/TV.
When I take the fuse out for this, then the battery stays full.
The TV is the smaller type (not wide screen).
I have tried taking out the Sat-Nav disc but still it drains the battery.
Are there any other tests I can perform myself at home?
Does anyone have any suggestions for me on how to overcome this?
If it means buying a new centre console - are these easy to fit, and how much would it cost?
Many thanks.
RN55ONE is offline
post #2 of 4 (permalink) Old 05-31-2012, 09:23 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
It might not be the Comand unit even if the current consumption goes away when you remove its fuse. It could be fixed from a software update or it could be another device at the same CAN bus that keeps the bus alive.
Diesel Benz is offline
post #3 of 4 (permalink) Old 06-08-2012, 12:52 PM Thread Starter
hi, my dad (whos car it is) took it to a garage that says the voice command part of the control centre is at fault.
they said that the voice command part was optional and it could be disconnected without having any ill effects with the control centre.
Is this true?
if so, how would I disconnect the voice command part of the unit?
(Or is there a fuse I can take out?)
RN55ONE is offline
post #4 of 4 (permalink) Old 06-12-2012, 10:35 AM
Date registered: Jun 2012
Pulling fuses is not the proper way to check for a current draw. Best way is to use an amp clamp. Checking for a current draw is not for the DIYer. Unless you have deep pockets and want to throw parts at it to try and find the draw. You need proper tools and time! But yes, I have replaced many comand units for a current draw. Sometimes a software update can be the fix too.
BenzTek Motorsports is offline
    Flat battery / battery drain tip hox C215 CL-Class 0 06-14-2011 05:41 AM
    Battery drain problem 2000 S500L (W220) Askaroladi W220 S-Class 24 11-26-2008 08:43 AM
    Battery drain help Oracle12345 W201 190-Class 4 11-07-2008 05:36 PM
    Battery drain E55 AMG thorndale W211 E55 AMG, E63 AMG 1 06-08-2007 09:16 AM
    Battery drain Binny W201 190-Class 4 11-03-2006 05:09 PM
