Display defective error message on W210 1996 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-30-2012, 11:36 AM Thread Starter
Date registered: May 2012
Vehicle: Mercedes E320 1996 w210
Post Display defective error message on W210 1996
Recently when it got hot here in Europe i noticed my engine temperature going up to 120 degrees celsius! (248ºF!!!!) when in idle or driving up the hill. So i started in normal order by changing the viscus. When nothing happened i continued by changing the thermostat, temperature sensor, water pump, than continued with the instrument cluster, the radiator, than measuring the presence of CO2 in the water (came out negative) and finally lost all the ideas.
Ok, than i said, let`s open the engine and changed the head seal.
And finally after spending almost 1.500 USD the problem dissapeared.
But than an error message appeared saying: "DISPLAY DEFECTIVE" or on european cars like mine "anzeige defekt" and showing the radiator icon.
First i thought it was the expansion tank sensor and changed that too but the problem persisted. And finally, changed the washer level sensor for USD 40 and fixed the problem. I saw the comments saying that you should recode the instrument cluster but the MB dealer said w210 1996 belongs to older generation MB thad do not need to recode a cluster.
The sensors are connected parallel and may swap the error messages.
Hope this helped.
PS if your engine ever goes to maximum change the head seal right away instead of trying other
David Baumgarten is offline
post #2 of 2 (permalink) Old 05-31-2012, 02:51 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld
eric242340 is offline
    "DISPLAY DEFECTIVE" Message Kiwicha W220 S-Class 11 05-06-2016 03:26 AM
    display defective error message pvel W210 E-Class 32 09-28-2014 05:14 AM
    Display Defective Message, Passenger door control malfunction jadoux C215 CL-Class 2 10-27-2011 06:48 AM
    "Defective Display" Message Braingears G-Class 3 11-09-2005 10:24 PM
    2000 CLK 320 shut off while driving( Defective Display message) knolyn C208/A208 CLK-Class 1 04-09-2005 08:30 PM
