computer code P0335 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-27-2012, 11:26 AM Thread Starter
Date registered: Oct 2011
computer code P0335
I am getting this error message. Does anyone know what part I need to order to get this repaired?
bears36 is offline
post #2 of 3 (permalink) Old 05-27-2012, 12:24 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Are you having any symptoms?
P0335 Crankshaft Position Sensor A Circuit Malfunction (L5)
Musikmann is offline
post #3 of 3 (permalink) Old 06-06-2012, 12:51 AM
Date registered: May 2012
A P0335 "check engine light" code could be caused by:
Damaged CKP sensor connector
Damaged reluctor ring (missing teeth or not turning due to sheared-off keyway)
Sensor output open
Sensor output shorted to ground
Sensor output shorted to voltage
Failed crank sensor
Broken timing belt
Failed PCM
go to garage repair it or get code scan tool clear it by yourself.
_____________________________
never say goodbye!
Chinasinoy Blog
alexander.bulygin is offline
    Code: P0335 = Crankshaft Position Sensor - How to Replace? ZEvans W163 M-Class 3 05-10-2011 01:31 PM
    Engine stops while driving ... code P0335 athus3 W163 M-Class 9 06-01-2010 04:07 AM
    CPS code P0335, P0130 and P0150 - SLK320, 2001, 120K rgdeja R170 SLK-Class 3 05-13-2010 07:53 PM
    Check engine light and code P0335 Samsonite W203 C-Class 7 09-17-2009 06:08 PM
    Computer Code Reader TheMadMidget W202 C-Class 1 08-27-2005 11:31 PM
