can someone tell me how to align 5.0 timing chain? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-25-2012, 08:26 AM Thread Starter
Date registered: May 2012
even if someone cud just tell me what the cam marks are and what they align with.Im gonna order a book from somewhere but Im starting tearing into this thing now.i ts a 95 s500. Im pretty sure thats the 5.0 eng.ine, its the v8. also should I start by removing the core support and radiator or do u guys leave them installed? Thanks
blackedoutbenz is offline
post #2 of 2 (permalink) Old 05-27-2012, 08:11 PM
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
this isn't a DIY thing if you don't know what your doing. you will just have a torn down s500. However you mark the cams/crank/distributor with a sharpie before tearing down. Make sure it's exact, otherwise you'll have a huge headache. I know theres a writeup on marking cams in the w126 section, different motor but same concept.
I'd still advise to not do it.
Benznoob26 is offline
    NEW FS: Radiator fluid, 190e- fuel filter/timing chain/timing chain tensioner ect Benznoob26 For Sale/Wanted/Trade/Giveaway 4 08-29-2010 11:31 PM
    Timing Chain Master Link - will Iwis work on the BECK ARNLEY CHAIN?? xxxbradxxx W123 E,CE,D,CD,TD,TE Class 8 10-17-2009 05:53 AM
    Feeding in timing chain, attaching to old chain petecooke W123 E,CE,D,CD,TD,TE Class 4 09-18-2009 10:36 AM
    IWIS timing chain compared to JWIS timing chain. ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 5 07-01-2008 07:22 PM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
