Is 120 the right temp on a 420 SEL??? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-21-2012, 12:26 PM Thread Starter
Date registered: May 2012
I have read here and there that temperature on my 88 420SEL can go up to 120, this is normal and there should not be a problem. My aux fan works and comes on, oil and coolant are where they should be, and still in not-so-hot heat of 70 outside, the gauge goes up to near 120 after 20-30 minutes of regular driving. Air really does not work well, and things just seem HOT.
The other day, the hose blew off the radiator soon after I parked, spewing coolant everywhere.
This all does not seem normal.
Anyone have any insite into this?? Is this a thermostat problem?? THANKS
mi420SEL is offline
post #2 of 2 (permalink) Old 05-21-2012, 09:14 PM
eric242340's Avatar
Quoted: 309 Post(s)
Welcome to Benzworld, it is not normal, thermostat? put your hand on the top hose and then the bottom hose and if they are the same temperature then the thermostat is working fine. Also try cleaning the fins in the radiator with a high pressure washer.
ERIC.
eric242340 is offline
    2008 GL450 P0128- coolant temp below thermostat regular temp gbokas X164 GL-Class 5 05-06-2016 12:44 PM
    Coolant Temp sensor (kick in at lower temp) kianbeng R170 SLK-Class 1 04-29-2012 10:33 PM
    Temperature variance -- actual temp vs. gauge temp reading soundquest W124 E,CE,D,TD Class 7 06-19-2011 08:03 AM
    Dead Temp Guage after replacing temp sensor Stevewelsh W201 190-Class 5 11-29-2010 03:52 PM
    When outside temp is higher than 40', how come the temp gauge still shows 40'? noelb W163 M-Class 5 04-16-2002 01:43 PM
