VW jetta 1996 vacuum pump on my central locking system - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-20-2012, 05:15 PM Thread Starter
franqui.charon@gmail.com's Avatar
Date registered: Apr 2012
Vehicle: Mercedes Benz S420 1999
Send a message via AIM to franqui.charon@gmail.com
Recently I modified my central locking system using a vacuum pump from VW jetta vacuum system and am working perfect. The Mercedes vacuum pump still around $$$600.00. And was made this modification for less than $40.00, from the junk yard, I used only the internal pump. This vacuum works .05 cfm higher than the original and the time delay is less than the original set point. See the pictures attached. I hope this information help others with the same problem.
ID:	445674   Click image for larger version
ID:	445675   Click image for larger version
ID:	445676   Click image for larger version
franqui.charon@gmail.com is offline
    Central locking - Vacuum pump philiplg W168 A-Class 47 07-27-2015 07:00 AM
    Central Locking Vacuum Pump JoeGons W210 E-Class 12 08-14-2011 03:44 AM
    Central Locking / vacuum pump pamp W126 S,SE,SEC,SEL,SD,SDL Class 5 09-16-2010 09:52 PM
    Looking to buy central locking vacuum pump ulflei R129 SL-Class 9 07-01-2009 05:41 AM
    central locking system vacuum pump replacement - help please oggo W140 S-Class 2 11-09-2007 09:14 AM
